You can use your system to charge both sets of batteries, but not at the same time. You may have to change battery types of an option. Different types and different levels of charge will cause problems if connected to same controller.
One solution is to add a second controller tied into the panel feed line and use it to control charging for the other battery bank.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
