Some roof types are perfect for thin panels. But, clearly there are pros and cons to either type... four 100W panels would weigh about 16# total, not including about that much in wiring... a pro, while some question how long they will hold up.
I would assume that the mini isn't a walk on roof. So, like you did... keeping it at the sidewall works great. If there's a roof, there's a way... even with conventional glass / aluminum framed panels. I've seen these mounts that you used and thought they were neat (sorry, the 60s lives on).
For the flexible panels... a person could double side tape them down, dicor them down or eternabond them down... probably velcro them down. It would cost way way more for the eternabond method, and I wouldn't be relying on velcro.
Not sure I would have bolted thru, but it sure as heck isn't going to blow off.
WW
Hyper Lite was sold
2017 F-250 4x4 6.2L Gas
