Connectors that I use for Solar
For the panels themselves, most come with a MC-4 style connector which are weather proof. You can run the panels in series but only if your controller can handle the higher voltage. This will help with the loss from high currents.
Two controllers on the same battery bank will fight each other so using one controller for both solar banks is preferred.
Check into the Anderson Powerpole connectors. They are genderless and come in ranges from 15-45 Amps for the small shell. The medium shell goes to 75 Amps.
My trailer has nothing on the roof so I ground mount mine so I can move them around to stay in the sun: East in the morning and West in the afternoon. I run them through a Renogy smart controller and direct attach to the battery bank.
If you can't cut the cord on all the AC equipment you might never have enough panels to keep up with a microwave oven, coffee pot, large screen TV, Berk-a-liner massaging chair, 6 tons of air conditioning, and a nuclear centrifuge.
A rule of thumb is that if an AC appliance draws 5 Amps of current the 12 Volt DC input into the inverter will be at least 10 times that amount or 50 Amps.
2018 Rockwood 2509S Mini Lite
Past: 1984 Road Ranger 20', 1988 Kit Companion
1984 Starcraft 24 foot popup
TV: 1999 Dodge 2500 Cummins 4x4
Honda EU2200i Generator, 300 Watts Solar
Ham Callsign KD7UM
