Old 09-07-2018, 01:19 PM   #1
Struts for under bed storage
Has anyone added struts to help lift the bed to gain access to the storage?
Ours didn't come with any and it's a royal PITA to hold it up while trying to get things in and out. I'm looking for something to help make this easier.
TT: 2018 Coachmen Freedom Express 287BHDS
TV: 2018 F-250 6.2L | 3.73 E-lock | Payload: 3,158 lbs | GVWR 10,000 lbs
magnetic157 is offline   Reply With Quote
Old 09-07-2018, 01:30 PM   #2
Witch Doctor's Avatar
Check Napa Auto Parts, they have some that will work, just make sure you get one with enough psi to hold it open.
Coachmen M/H
Concord
2018 / 300 DSC
Old 09-07-2018, 01:40 PM   #3
Ours came with them. I have seen the air cylinders at Walmart also.
KKonyha is offline   Reply With Quote
Old 09-07-2018, 01:47 PM   #4
Lavanture Products are brands Forest River uses. This is the supplier you can go online and order from.
https://industrialhardwaredirect.com...y/gas-springs/
2019 Wolfpup 18TO
Who went in the way before you, to search you out a place to pitch your tents in, in fire by night, to shew you by what way ye should go, and in a cloud by day.
Deuteronomy 1:33
wolfpup64 is offline   Reply With Quote
Old 09-07-2018, 01:50 PM   #5
I bought a set from here: RV Bedlift Kits
latner is offline   Reply With Quote
Old 09-07-2018, 01:51 PM   #6
mdstudey's Avatar
We add 100 pound struts from Hatchlift. Kind of a PITA to install but oh so worth it. I had upgraded the mattress that is a lot thicker and heaver than the one that came with it. Plus it sure made doing any work in the storage compartment easier. We don't have a pass through.
Chuck & Denise + Pata, The Purple Princess Peanut, Ziggy the pole cat and Kazumba the parrot
2015 23 BD Gray Wolf
2008 Dodge Ram 2500 TX Edition 2015 - 7 nights, 2 trips, 2016 - 2 trip, 24 nights, 2017 1 trip, 3 nights 2018 1 trip, 93 nights
mdstudey is offline   Reply With Quote
Old 09-07-2018, 01:55 PM   #7
I bought a couple of 100 lb. ones from Amazon. As previously mentioned, a pain to install but well worth it. There is no way my wife could open it before, now it's easy.
Draggo is offline   Reply With Quote
Old 09-07-2018, 02:24 PM   #8
We have a Vibe 308 BHS and our bed did not have any struts either. I bought a pair at Camping World, but I also had to buy some 1x2 strips to reinforce the upper sides between the corners, so I could install the strut connections and have support. It was fairly easy.
1) Used a brad gun to install the 1x2s, then a furniture crayon to mask the brads.
2) I then determined the placement of the struts, marked the locations for the strut supports and attached a 4" 1x2 to which you screw the strut support.
3) I then removed the mattress from the bed and flipped the storage cover all the way back, placed a scrap block of wood between the cover and the bed support (just in case my screws decided to penetrate deeper)
4) Attached the small end of the strut to the wood supports.
5) Flipped the cover back with the struts attached and determined where the strut support needed to be placed on the side of the storage compartment.
6) Depending on the strut support bracket you can either screw into the 1x2 upper support or add an additional piece of 1x2 below the upper support to attach the large end of the strut to.
CrocNC is offline   Reply With Quote
Old 09-08-2018, 12:50 PM   #9
Struts
It sounds like you might have an easy fix! We have a 24ft 2016 FR 2401w MBS with a full slide! Unfortunately the box under our queen master bed is screwed closed! Nothing inside! We would like to do the same thing for the added huge inside storage we would gain! We haven’t a clue about what to do! Any ideas? Dan & Gerda
Dan n Gerda is offline   Reply With Quote
Old 09-08-2018, 04:37 PM   #10
I wanted the same thing for the storage area under our queen bed. Instead of buy anything fancy my husband used a 1” x 2” board with bolt, washer and nut fastening to the wooden divider and a sm pc of wood on the top to rest it under so it won’t fall. Didn’t cost anything, had left overs, a little time and works great.
Ncgrandma is offline   Reply With Quote
Old 09-08-2018, 06:53 PM   #11
I have one for sale
I have a brand new Standard Bedlift Kit made by Hatchlift Products that I'll sell you for $30 plus shipping. These sell on Amazon for $70.99 ... message me if interested....
https://smile.amazon.com/Platform-Be...it+queen&psc=1
stevegotl is offline   Reply With Quote
Old 09-08-2018, 08:18 PM   #12
bikendan's Avatar
Sent you a PM.
Old 09-09-2018, 02:45 PM   #13
The gas struts come in various lengths and pressures (for varying weights). The lengths depend on your mounting points. Lots on Amazon.
My bed had the gas assist struts but they were mounted one on the far side and the other about 18" in from the side because of the water pump and heater location. My handle was positioned mid-way between the struts, making for a twisting, awkward lift due to unbalanced weight. I first moved the lift handle to the bed center but the off center struts still made for a twisting lift. I felt for the best balance point when lifting the bed against the struts and put the handle there. A few extra holes, hid by the bed covers, but a much easier lift.
2019 Cherokee Wolf Pup 16BHS flipped axle
2019 Ford F-150 S-Crew 5.5 bed V8 w/tow package, TBC, Tow Mirrors, 3.55, 7000# GVWR, 1990#CC
Husky Centerline TS WDH 400-600# spring bars
Boomerweps is offline   Reply With Quote
Old 05-31-2021, 07:02 PM   #14
I bought the struts from amazon. It's a LOT of trial and error= multiple holes. Lol. I finally got it right after approx two hours! I spent more time looking for bolts, nuts and washers, and going back and forth to the fridge for some cold beers. Ill adjust later when I upgrade to a memory foam mattress. Cheers!
2018 Sonoma 220MBH Mountain Edition- Arctic Pkg
* 2021 Jeep Gladiator with Max Tow pkg *
Life is sometimes short, make the memories last longer- go RVing and just enjoy Life
roadster is offline   Reply With Quote
Old 06-01-2021, 10:08 AM   #15
100 lb. struts are SUPER powerful!
I used the basic guidance from a poster here and did make a couple of changes. Again, I don't think 100 lb. struts are needed. 50-60 would be a easier to deal with!
Robert H
TT - 2021 Grey Wolf 23MK LIMITED, Original tires
TV - 2018 RAM 1500 Crew Cab 2WD 5.7 HEMI 3.21 Axle Ratio, Stock Goodyear 20" tires
Luckyboy is offline   Reply With Quote
Old 06-17-2021, 08:47 AM   #16
Here are my measurements.
ID:	257200   Click image for larger version
ID:	257201   Click image for larger version
ID:	257202   Click image for larger version
ID:	257203   Click image for larger version
Old 06-17-2021, 09:40 PM   #17
Man, I wished I found your measurements earlier. Surely could have saved me time. Oh well. Thnks for posting again.
Old 07-21-2021, 03:19 PM   #18
Did you figure anything out because I would like to add the same thing!
smyates57 is offline   Reply With Quote
Old 07-22-2021, 06:29 PM   #19
I mounted two 55 pound struts, 20" long, bought from Amazon for about $22 for a pair (https://www.amazon.com/gp/product/B08P39MTCK/).
It certainly is a PITA, especially because it is imperative that you reinforce both the bed platform (where do they get such cheap particle board?) and the bed frame sides.
The bedframe sides are a sandwich of two sheets of cheap veneer plywood (might as well be cardboard) with foam particles in between. The struts put considerable force on the mounting brackets (which should be no surprise) and these cheap materials will not hold a screw. I mounted pieces of 1x4 on the inside of the frame, screwing these into the base. I put a small plywood patch under the platform, attaching the bracket through platform and patch with machine screws and nuts rather than wood screws.
dfriedman is offline   Reply With Quote
Old 08-08-2021, 05:56 AM   #20
Some of the pictures no longer display
Can you repost the pictures please? Some of them are not displaying. I se a lot of instructions and most of them show mounting the other way whcih I think is wrong.
Thanks.
dedobias is offline   Reply With Quote
bed, storage
