+1 for going with an HDMI splitter. Splitters with an external power supply tend to work better than those powered by the HDMI cable. At least that's one man's opinion.
If your HDMI cables are longer than about 20 feet or so consider active cables. They have an amplifier in the source and of the cable and work over long distances. Monoprice.com is a good source. The higher end TVs have multiple modes such as Theater, gaming, etc. Most modes introduce processing latency, however a Gaming mode minimizes all processing so the action in more like real time so if you're interacting via a game controller there is no latency. I'd also have the audio muted on one TV just in case there is audio lag. Should all work out just fine.
Originally Posted by Vontriple
You may need to run an hdmi splitter. You plug the fire stick into that, and run 2 hdmi cords, one to each tv. You would need to get an all female, if you get one of those with a male for the input you won't be able to plug your stick in.
