Old 11-23-2020, 06:26 PM   #1
Tips on adding a window
I'll be adding a window to the top bunk of an apex nano 208bhs. It has an azdel exterior. Any tips before I make my first hole with a holesaw? Planning to put the new window above the old one.
Gerogesin is offline   Reply With Quote
Old 11-24-2020, 11:41 AM   #2
Measure thrice, cut once. No repairing Azdel panels, no pressure
You might want to ball park where you want it on the outside, measure, then remeasure on the inside to match the current window. Drill a few marker holes from the inside using the new window’s frame inside edge. Then go back outside, draw the inside of the window frame, and use that for the first rough opening hole cut. THEN you can measure and draw for the finish hole cut that matches the current window.
You may find out you need to reinforce across studs. Likely easiest to use a hole saw to Swiss cheese the stud up the wall between the Azdel and inner paneling, then chisel out the rest to inset a cross stud reinforcement.
Don’t push on the hole saw or any saws, let the blade do the work chewing away the wood and the Azdel.
Found a good amount of RV windows on Amazon. Considering one that opens for my door.
2019 Cherokee Wolf Pup 16BHS flipped axle
2019 Ford F-150 S-Crew 5.5 bed V8 w/tow package, TBC, Tow Mirrors, 3.55, 7000# GVWR, 1990#CC
Husky Centerline TS WDH 400-600# spring bars
Boomerweps is offline   Reply With Quote
Old 11-24-2020, 12:22 PM   #3
Thanks for the advice. I attached a picture to give you a better idea. Its hard to landmark the exterior and interior without drilling a small hole first. First I'm most worried about any metal studs being in the way and secondly worried about any water penetration. I think I can fix the latter with good rv caulk.
Is there some sort of stud finder than can detect metal studs? An xray machine would be good here!
Old 11-24-2020, 12:57 PM   #4
flymhi's Avatar
Most electronic stud finders have a deep stud scan as well as metal scan. I would be concerned about electrical that may be routed in the area. If you have access to a wire tracer/toner, I would hook it up to the 12v trailer plug and tone near the area listening for the alternating tones in the area you plan on cutting. Pics of both tools below.
ID:	243572   Click image for larger version
2015 Denali Duramax 2500
2017 Coachmen 229TBS
flymhi is offline   Reply With Quote
Old 11-24-2020, 02:04 PM   #5
Seeing through the wall.....
The best idea for seeing what's in the wall whether it be cables, studs, pipes, or whatever is to use a Walabot wall scanner device. This device in conjunction with an app on your phone "sees" through the wall. It really works and can discriminate between wood, metal and plastic objects. Best I've found short of an x-ray.
Happy drilling & cutting!
http://walabot.com/
HaulinMyHarley is offline   Reply With Quote
Old 11-24-2020, 02:31 PM   #6
rollscanardly's Avatar
You could get a borescope and drill a hole large enough to insert the lens.
Of course, the borescope would have to be able to light up, which many do.
Then you could look around in between the walls.
Rich
"rolls down one hill, can 'ardly make it up the next..."
1999 21' Wildwood WDF21RK
2006 Dodge Ram 2500, 4x4, Quad cab, 5.9L Cummins, 3.73 gears.
rollscanardly is offline   Reply With Quote
Old 11-24-2020, 04:22 PM   #7
If it was me, I would cut the inside paneling first to see what is inside. If everything looks good to go, drill thru to the outside. Its easer to fix the paneling than it is the outside.
Wolf26 is offline   Reply With Quote
Old 11-24-2020, 04:45 PM   #8
Always Learning
Rich
Aren't most RV walls thin wood inside, foam in the middle, and then the outer skin? I'm not sure you can really "look around in between the walls".
Checkout my site for RVing tips, tricks, and info | Was a Fulltime Family for 5 years, now we're settlin' down for a spell
ependydad is online now   Reply With Quote
Old 11-24-2020, 04:51 PM   #9
I forgot to attached the file.
I will definitely try that app to see if it works. So far the plan is to use the electric current tester, deep stud finder (hoping it'll work for this purpose) and try that app!
Old 11-24-2020, 05:46 PM   #10
DouglasReid's Avatar
Rich
It is an exterior wall, it is going to be full of insulation........he won't be able to see much except directly in front of the lens, and good luck figuring out where that is at any given moment.
2008 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline   Reply With Quote
Old 11-24-2020, 06:27 PM   #11
D W
D W's Avatar
Take a look at that outside section early in the morning when it's cool, just as the sun is coming up. You should be able to get rough idea of where the stud work is located.
2016 Salem 27RKSS
D W is offline   Reply With Quote
Old 11-25-2020, 10:15 PM   #12
Why not just get the drawings from Coachman? Also there may be an issue with the header board above the existing window. Jay
2016 Rockwood 2504s.
TV: 2014 Silverado 1500 double cab.
Jay2504 is offline   Reply With Quote
Old 12-30-2020, 01:14 AM   #13
Here is where the factory is putting the window in the newer 2021s. This is a 208BHS
fshrlou is offline   Reply With Quote
Old 12-30-2020, 01:41 PM   #14
Are there any factory videos on YouTube that can give you a better view of studs/wires?
WanderMore is offline   Reply With Quote
Old 12-30-2020, 03:09 PM   #15
I tried that Walabot unit and did not like it at all. Readings were not much better than a regular stud finder and trying to use it with a phone is very clumsy. The materials inside the camper wall may have different heat signatures at different times of the day. A Flir camera can help you see what's inside.
I was able to trace some power lines by running a space heater on the wall outlet which warmed the power cable enough to see where they went in the wall.
SmackIt is offline   Reply With Quote
window
