I have a couple suggestions. First, look at the wall at the main entrance door where they mounted the strike plate. The wall where you’ll be mounting the track for the slide topper is probably the exact same composition and thickness. Second, double-check with the factory.
I’ve had slide toppers installed on 2 trailers. I wasn’t brave enough to do it myself either time but I did insist that the installer use stainless steel screws if the kit didn’t come with ss hardware.
Good luck.
