Old 12-30-2010, 09:57 AM   #1
MtnGuy's Avatar
TV Interior Gear Junkie Solutions
After Great White's excellent lower console project, I thought I would show the lazy man's way.
I don't like drilling holes for gear placement, so I came up with these 2 solutions:
The lower console in my case came from an Advance Auto. I have my emergency scanner and CB bolted into the console, and the console fits tight in between my dash and center console. The external CB speaker and the 3 way splitter are just set in place.
I cut a piece of plexiglass to fit in the upper dash tray for my TPMS, ScanGauge II, and my GPS. The buttons on my TPMS are a little difficult to get to, but I only check the individual tire pressures every 1/2 hour or so, so it is not a problem.
Just thought I would put some ideas out there for those "lazy" members that don't have Great White's talent.
Old 12-30-2010, 02:40 PM   #2
Now a "Top Member"
EdJunior's Avatar
Hooey Chap. That is a mess o' gear for sure. But that's also a good job of keeping it all together and tidy.
Ed and Sharon
2010 Wildcat 28RKBS
2019 Ford F-250 XLT - AWESOME Truck!
Retired AF MSgt
Old 12-30-2010, 04:44 PM   #3
MtnGuy's Avatar
Sometimes, I even have a chance to glance at the road.
Old 12-30-2010, 06:34 PM   #4
Here is my install. My truck had a cassette player in it. I removed it and modified the opening in the trim to fit over the radio head. I velcroed the radio to the slide out tray from the manufacturer that held the tape deck. That is my HF amateur (HAM) radio, gives me state to cross country/ over seas communications from my truck. The other radio is a dual band, 2 meter (VHF) and 70 cm (UHF) amateur radio, used for vehicle to vehicle or county wide using an available amateur repeater. The dual band radio has a detachable head and can mount about 25 feet from the main part of the radio if needed.
Kirk, KN1B
2013 Cardinal 3800FL
2009 GMC 3500HD CC LB SRW
kbrown1075 is offline   Reply With Quote
Old 12-30-2010, 06:39 PM   #5
MtnGuy's Avatar
That looks much neater than my setup. Nice.
Old 12-30-2010, 07:05 PM   #6
Thanks. Mobile 2 way radio installs are part of my job but I am a bit more particular on my own!
Kirk, KN1B
cb radio, console, mount, tpms
