Originally Posted by Bourbonfan
I have purchased a 2020 Wolf Pup 16FQ. The previous owner drilled several holes in the walls. Also, removed something they had stuck to the wall, and pulled off a 3 inch square of wallpaper. I'm looking for suggestions on how to repair this damage. Can I wallpaper over the original factory wallpaper? Thanks for your help.
Since it’s a 2020 model, you can probably get the exact wallpaper used on on your RV from Forest River, and make a color matched patch. For various projects, I have obtained the matching color and pattern for my 2020 Sunseeker, both for the wallpaper and the woodwork. Forest River calls it “seam tape”, but depending on the particular tape you need and how it comes from the supplier, it could be available in a width anywhere from an inch to 4 feet.
Forest River will not sell to customers directly, so you would need to go through a dealer, and provide them the year, model, and interior color scheme of the RV.
The attached pictures are an example, showing the 4 foot wide wallpaper I ordered from Forest River. It’s peel and stick.
