Wasn't expecting to be in freezing weather but am for a bit.
Have a remote thermometer and it never got below 34 degrees in the covered underbelly(at least where the thermometer was) and just running the fireplace. Low twenties and upper teens overnight. I run the propane now when it gets that low but wanted to see some numbers with just the fireplace running.
Pass thru stayed above 34 also but when I opened up the compartment with the water pump a laser thermometer said 32 on the pump. Water was fluid in the filter container.
Since the pass thru is unheated I installed a light socket assembly with an outlet on it. Cut some cord and put two male plugs on it with one end routed to a bracket under the camper. The end at the light is tie wrapped to the fixture and in a groove, should stay put.
Got down in the high teens again the other night and the water filter/pump compartment never go below 50 degrees. I did put a 150 what bulb in it but I believe a 100 watt would be sufficient.
Can run an extension cord from the outside GFI on the camper or the 15 amp on the pedestal.
I've done the same set up with my garage door openers as vibrating openers are tough on bulbs. Just need to get a screw in receptacle for the bulb socket. Even added multiple lights.
Now it I could just do something similar with my low point drains.
