Old 07-03-2017, 09:18 AM   #1
Water Filter
Has anyone changed their water filter and the location? The original FR1 replacement filter is expensive. Plus mine is installed over the water pump and you do not have enough room to change filter unless you tilt the housing and still have problems doing so.
Thanks Tervio
tervio is offline   Reply With Quote
Old 07-03-2017, 09:30 AM   #2
Yop, took mine completely out and just use a filter on the end of the hose.
2019.5 Rockwood 2509S
Toddupton is offline   Reply With Quote
Old 07-03-2017, 09:44 AM   #3
Lots of reports of these filters cracking and flooding trailers. Remove it.
Put in a 1/2" coupler from Home Depot. 67 cents.
Name:	Filter replacement coupling.jpg
2011 Traverse LT, 3.6L, FWD
Old 07-03-2017, 10:06 AM   #4
Thanks Tervio
toddupton and rockfordroo have given you the best advice, ... go with an outside-the-trailer filter, ... the Camco blue one, ...
https://www.walmart.com/search/?quer...ypeahead=camco
fella10 is offline   Reply With Quote
Old 07-03-2017, 10:21 AM   #5
Smartest move. Anything that involves water...inside a the trailer...= BAD !
We're thinking we'll go 5er next year and I'm documenting many of the issues addressed out here and I'd consider yours as "High Priority".
TheWolfPaq82 is offline   Reply With Quote
Old 07-03-2017, 12:22 PM   #6
Thanks for the suggestions, I will do something soon. I have seen other comments about that filter housing but out of sight-out of mind until I'm cleaning up a mess!
Thanks for the help
Tervio
Old 07-03-2017, 12:36 PM   #7
tmfaulksr's Avatar
water filter
we already had KW1/FR1 filters so we thought we would use them.
here is a filter holder that we purchased and then how
it looks in-line at our site . works well for our needs.
after reading all of the horrific threads on this issue i had to make
it a priority and remove it asap and make the alterations.
hope this helps
tmfaulk
ID:	143480   Click image for larger version
the faulks & prince
2012 Nissan Titan CC
Roadmaster Active Suspension, Firestone Airbags
2015 Rockwood 8289WS Diamond Pkg
2015 Puma 253FBS (sold)
2013 BMW R1200GSW
tmfaulksr is offline   Reply With Quote
Old 07-04-2017, 01:49 AM   #8
Do all TT have a water filter from the factory? Where would I look in my '17 Wildcat 24rg?
kollinr is offline   Reply With Quote
Old 07-04-2017, 02:22 AM   #9
bikendan's Avatar
No. My TracerAIR TT didn't come with a factory water filter.
I would ask other Wildcat owners, in the Wildcat sub-forum.
Old 07-04-2017, 04:54 AM   #10
"On the road again"
rjshiflet's Avatar
I buy replacement filters at WalMart or Lowe's or Home Depot. My fifth wheel holds a 10" x 2.5" filter that is much less expensive at these stores. I've had these on our current and past three trailers...no flooding, no leaking - just good, clean-tasting water.
Robert & Estha Shiflet
Georgetown XL 378TS
Jeep Gladiator Willys Tow Vehicle
rjshiflet is offline   Reply With Quote
Old 07-04-2017, 05:41 AM   #11
We like the Outside Water filter supported on the unit Not the Ground! Dogs seem to think they are "Fire Hydrants"! Youroo!!
water, water filter
