Our Sunseeker was equipped with the external style water fill:
Where I prefer the style that has a door, which has a cleaner appearance, and tends to be a bit more sanitary. That, and I like the fittings in white rather than black. Thus, I took on this little project:
First, I reworked the new fitting, as it had lots of areas where water would enter the wall. Odd they would design something that is an access for water but is not designed to keep the water where it should be...
I added a piece of PVC over the latch slot, glued in the fill pipe, and replaced the lanyard with nylon bolts. No water will get into the wall on my unit:
After reworking the new fitting, I removed the old fitting & started in on enlarging the opening:
Enlargement complete:
Installation complete. When setting up the thumb latches and locks, I have a method to my madness - if the latch/lock is oriented horizontally, it is latched/locked, and thus is ship-shape, read to set sail. If it is vertical, it's unlatched/unlocked. While locks don't need to be locked to be underway, latches do. Thus, at a quick walkaround without touching anything, I can verify everything is latched, and optionally locked.
- Exterior view:
New lanyard, new nylon bolt on the cap:
Fitting from the inside:
And if you are curious about the makeup of the Azdel side panels:
There's no wood (luan) used in the paneling, and thus very little chance of wall separation! I like it.
--Bruce.
