Old 07-13-2020, 06:53 PM   #21
ESGWheel's Avatar
Here is the ‘mapping’ from the Honeywell t-stat. I would expect that any t-stat, smart or not, has this same mapping. And also below is the wiring diagram.
About the wiring diagram:
The color of wires is simply how mine was wired; while some say there is a convention for the colors, there is no assurance that it is followed. The thermostat wire they used in in my RV was the 7 Wire type, of which 2 were unused. Also for these older RV systems, there is a DC voltage that is used to close the relays in the HVAC unit; for example on a call for heat, terminals W and Rh are shorted together by the thermostats own internal relays and it thus passes this DC voltage to the HVAC relay for “Heat” allowing it to close causing the heater to come on. So I simply spliced into the existing ‘green’ wire that goes to Rc/Rh with one side of the 24VAC supply and used an existing, but unused, wire to carry the other side of the 24VAC to the C terminal. How this works is explained in more detail in the ‘theory’ section above.
Hope this helps.
Name:	Terminal Mapping Chart.png
ID:	233867   Click image for larger version
Name:	Terminal Wiring Diagram.png
ESGWheel is offline   Reply With Quote
Old 07-26-2020, 09:53 AM   #22
ESGWheel's Avatar
That nagging feeling!
So, all is still working wonderfully. But it was nagging at me: is the AC signal getting thru and riding around on my Trailer’s DC system? Would this have long term effects to my electronics? What about the lead acid battery?
Not having an oscilloscope, I checked it out with my trusty voltmeter. No signs, but could it still be there? Only an O-Scope would satisfy my concern. But even used ones are expensive. Could I justify the expense thinking I could use it for some of my other hobbies? As we all know, projects are simply a reason to buy more tools Nope, even 20+ year old scopes on eBay were not reasonable, at least for me. Enter QUIMAT. I had no idea they had a little handheld wannabe O-scope. Done.
Well it arrived and below are the pics showing the nice 60Hz sine wave on the C Wire. Other pic is showing no signal at all on the Trailer’s 12VDC system, with the A/C and Heat on or off. Way cool. That nagging feeling gone!
ID:	234838   Click image for larger version
Old 07-26-2020, 01:23 PM   #23
You could have just used a regular multimeter set on AC in the millivolts range to see how much ripple is on the DC.
That being said, Its nice to have a oscilloscope. I have this one for hobby use like Arduino and other micrcontrollers. https://www.amazon.com/Rigol-DS1054Z.../dp/B012938E76
babock is offline   Reply With Quote
Old 07-26-2020, 06:16 PM   #24
ESGWheel's Avatar
babock
Recall the part: "As we all know, projects are simply a reason to buy more tools" so shhh, as I justified the cost of the QUIMAT based on the 'need'
Boy that full featured digital scope sure looks sweet! Now i just gotta think up some projects to justify it
Old 07-26-2020, 06:36 PM   #25
babock
Amazing what you get for the price. I have a few RV related Arduino projects in the works.
Old 10-29-2020, 07:13 PM   #26
Thanks for doing all the leg work on the 12VDC to 24VAC issue @ESGWheel. It appears that Power Stream inverter opens the door for many different residential smart Thermostats.
I don't care about the WiFi features and remote monitoring found in most, but I would like a programmable Bluetooth thermostat, has anyone seen something like that? The MicroAir is quite expensive and the display does not appear to be very good.
SmackIt is offline   Reply With Quote
Old 10-29-2020, 07:53 PM   #27
The micro air thermostat works great. As far as price I don’t really think there out of line. If you install the nest thermostat at your house your going to pay over $200 bucks. There is another option if you have the One control system on your Rv. I think it’s called ONECONTROL HVAC V2 DUAL-ZONE CONTROL for about the same money. One thing that’s great about the micro air is that it plug and play and the company stands behind there product. Tech support will work with you if you do have a problem. The one control has to be wired into the a/c control panel.
My Rv came with the one control tablet and auto level only. I’ve added the multifunction board to control the slides, awning and awning lights. I also added the light control module that will control all the lights. The lights are dimmable too. Then the final was the WiFi module so I can control all the above with my cell phone. The next module I will be adding will be the tank monitoring along with control for the water pump and water heater.
All the above as far as one control was around $600 bucks. The OneControl system above is real simple to install.
Sam
samgann is offline   Reply With Quote
Old 10-29-2020, 08:00 PM   #28
Old 10-29-2020, 08:47 PM   #29
Originally Posted by samgann View Post
Glad to hear you're happy with the Micro Air. I'm a fan of their soft starters, but the reviews have not been very good for the thermostat. $249 is crazy expensive, there are plenty of WiFi thermostats available for $50. The value equation for these types of devices comes down to bundling the "internet of things" features into the device. If you're looking for remote access to your thermostat anywhere in the world, I can see paying $249, however, there's a market segment like myself with 99% of our camping being completely off grid with no access to the internet. What I need is a simple programmable thermostat with a bluetooth connection to my phone so I can change the temp while in bed or outside the camper. The AirExcel 9430-3543 is perfect in that it's a plug and play installation with 12v power and bluetooth...they just forgot the programming part to set various temperatures at different times of the day.
I'll probably end up with the Micro Air, but it's going to annoy me every time I look at and think $249.
Old 10-29-2020, 09:27 PM   #30
Ya I see you point I guess convince at a cost. There are other options.
Have you seen these thermostats below?
Single zone Bluetooth https://www.rvpartscountry.com/New-B...e_p_30147.html
and a wifi https://zedly.com/a-wireless-smart-thermostat-for-rv/
Another Bluetooth https://www.camperid.com/dometic-rv/...13107-000.html
The Zedly Wi-Fi doesn't need internet. you can connect to with your phone and has scheduling too.
Just trying to help.
Old 10-29-2020, 10:09 PM   #31
Always appreciate some extra help.
The first one is the Dometic version of the Coleman Macht. Bluetooth, but no ability to program.
The second one isn't yet available and they want a $4.95 per month subscription. The subscription is required. I make it a point to never support a company that overcharges for electronics and then tries to force you into a subscription. They should be giving the device away for free. On top of the monthly subscription, they'll be harvesting data on every one of their users and selling it.
The third one is the same as the 1st, no programming.... the search continues.
Old 10-29-2020, 11:52 PM   #32
https://smile.amazon.com/dp/B010PTKW...ing=UTF8&psc=1
aeblank is offline   Reply With Quote
Old 10-30-2020, 12:06 PM   #33
Originally Posted by aeblank View Post
Thank you.
6 Year old technology.
No bluetooth
Terrible reviews
Must have internet to conrtol the unit via WiFi
Yes, I'm a hard one to please
Old 10-30-2020, 12:09 PM   #34
Originally Posted by SmackIt View Post
Thank you.
No bluetooth
Terrible reviews
Thermostat technology is way more than 6 years old. Just sayin...
The other points turn me off to it, too.... Just saved me $100, I think....
Old 10-30-2020, 01:43 PM   #35
flymhi's Avatar
Looking at this one as a replacement for my 2017 Digital thermastat.
Ebay currently has the white listed.
2015 Denali Duramax 2500
2017 Coachmen 229TBS
flymhi is offline   Reply With Quote
Old 10-30-2020, 01:49 PM   #36
Thank you.
No bluetooth
Terrible reviews
What is the brand and how old is your AC unit?
bradbill is offline   Reply With Quote
Old 10-30-2020, 02:12 PM   #37
2021 Surveyor Legend 240BHLE
Coleman Mach AC and Coleman Mach 9430-3382 digital thermostat on the wall. Works fine, but can't be programmed and it doesn't have bluetooth. Their 9430-3543 is a direct replacement with bluetooth, but it's not programmable.
Old 10-30-2020, 02:30 PM   #38
My bet is that you are going to have a tough time finding one like you want. Most Thermostats are WiFi so you would have to set up a Wifi System in your trailer. There are other problems associated with that regarding how your phone is tied up.
Out of curiosity, why is having bluetooth control of the AC/Heat so important? Don't get me wrong, love tech and I am a CTO of a tech company so I understand having tech gadgets.
The reason I asked you about your brand is that certain brands have a propietrary thermostat with a special interface between the thermostat and the Heat/AC system.
Old 10-30-2020, 03:06 PM   #39
The bluetooth part might be seen as a gadget thing, but I want it for 3 reasons.
#1 Adjust the temp while lying in bed, or anywhere I'm in proximity to the trailer.
#2 My thermostat is inaccessible when the slide is pulled in. It would be nice to pull it up on my phone via bluetooth to make an adjustment.
#3 Smart apps on a phone tend to be easier to program schedules than crappy button interfaces on wall devices.
I'm using a lot of Victron equipment for solar, inverting, etc. I like being able to check on things from my phone, with no reliance on WiFi. Victron offers that for most of their products.
I'm in the HVAC manufacturing business, these devices cost less than $10 to produce when they're dumb. Add in smart features, and they're maybe $20 - $30 max.
Old 11-21-2020, 03:10 PM   #40
Broke down and went with the path of least resistance. Mico-Air is plug and play and they're running a $50.00 off Black Friday deal starting today using discount code CMETRV.
thermostat, wifi
