Old 08-02-2020, 11:08 AM   #1
Window in entrance door
I am thinking of installing a window in my entrance door on my 2019 Wildwood T251SSXL toy hauler. There is no window now. Iím wondering if anyone knows the construction of the door, is there a frame inside? Would there be a framed area for a window or is the door a piece of foam Insulation. Any help is appreciated.
Marvk is offline   Reply With Quote
Old 08-02-2020, 11:12 AM   #2
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
Wouldn't a stud finder show the location of studs inside the door?
2018 RAM 5500 Laramie CC
Sold: Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Ordered: 2021....
Cypressloser is offline   Reply With Quote
Old 08-02-2020, 11:42 AM   #3
No definite framework found with a stud finder. Just a lot of erroneous blips, thatís why Iím wondering if maybe itís foam core sandwiched between the panels. Might have to remove door latch and see whatís in there.
Old 08-02-2020, 12:12 PM   #4
Head Rambler
It is just foam sandwiched between two panels.
Take some Frog (see what I did there ) tape and tape the area on both sides of the door where you'll be cutting, then mark out the cut line and carefully cut out the hole for the window.
I use an oscillating saw, but a drill and jigsaw will work. Be careful and go slow, especially on the radiused corners.
Gotta go campin!
Old 08-02-2020, 03:16 PM   #5
bikendan's Avatar
No studs in a RV door.
Old 08-02-2020, 05:21 PM   #6
watched a couple vids on u tube. going to put 1 in my 2019 artic wolf 315tbh8.
2019 Artic Wolf 315TBH8
CLE 216
grumpy glamper is offline   Reply With Quote
Old 08-03-2020, 10:59 AM   #7
The window frame and glass will add structure and strength, have don many on Vans.
Capt c is offline   Reply With Quote
Old 08-03-2020, 12:14 PM   #8
Just installed one in the 171rbxl.
Pretty easy to do.
The cardboard cutout on the box is bigger than what is needed.
Measure the new window and use that.
Take your time and it's a great addition to the door.
Mark Duerst
Raleigh NC
2019 Wildwood Xlite 171rbxl
2018 JGC Limited 4x4 w/tow
MarkDNC is offline   Reply With Quote
Old 08-03-2020, 12:24 PM   #9
Mark Duerst
Raleigh NC
Old 08-03-2020, 02:26 PM   #10
mlmay12's Avatar
Pretty easy to do.
Very nice job, I like good professional work.
2016 Dynamax Isata 3 24FW
2016 Jeep Willys JK
Yellow Labs Buddy Biscuit Eater, Mr. Jake (RIP), Casey Girl (RIP)
USN-RET/DOD-RET
mlmay12 is offline   Reply With Quote
Old 08-03-2020, 02:31 PM   #11
I put one in my Graywolf 26rr. Bought on Ebay for $85, has the inside shade you can pull down. It didn't come with a template, so I put 2" blue painters tape centered around where I wanted the window then placed the window on top, traced around window with pencil, measured in 3/8" from tracing to make cut line. Just be careful, the skin on both sides is very thin and could be prone to chipping. There is no interior framing or braces that I could detect. Put a bead of silicone caulking around window flange and push into place. Screw inside trim into place & you are done. A little scary to cut into the unknown but pretty easy once you get started. Good luck.
Wolf26 is offline   Reply With Quote
Old 08-03-2020, 07:47 PM   #12
Thanks for all the input. Looks like a lot of people have the same idea. Markdnc looks great and very professional On your Wildwood.
Old 08-09-2020, 08:56 PM   #13
larry2c's Avatar
Here's my installation on our Cruise Lite 210RBXL. It was very easy to do and we're really happy with the extra advisability - I can keep a better eye on the dogs now!
I just want to be outside!!!
'17 Salem Cruise Lite 210RBXL
'11 F150 5.0
Two shedding mutts
larry2c is offline   Reply With Quote
door, window
