Thanks guys.
I am rather happy with the results.
The framework of studs in the slide out is very inconsistent with anything I've ever encountered with residential frame construction. I expected that, but wow was it tough to find wall studs to secure it to. Maybe typical, but at least on mine, there is a stud that runs all the way across at the top of the slide out wall. And even doubled up over the 2 windows.
Luckily, the interior of the slide out is 11'-11 13/16" wide.
Basically, all it is a 1x3x12' mounted horizontal against the roof with L-brackets with 3 small braces(each end and the middle) and the zebra blinds mount to the bottom of the 1x3.
The board you see is a 1x6x12'. I found a spray paint that matched the other interior wood color and painted both sides of that board. It even shows a similar wood grain. I screwed the 1x6 to the 1x3 framework already mounted using regular wood screws with the head concealed by using screw caps that I had also painted the same color.
So, the whole thing is serviceable to access the blinds or easily remove if needed.
Most importantly, it looks much better than the cheap valances and curtains that were installed from the factory. As you can see from the one picture, I really didn't have much choice but to replace it.
Total cost, including paint, was about $70
Now, my next project is to do something with that jacknife love seat. It has just never been comfortable to sit on and way to small for anyone beyond a small child to sleep on. I have no small children. I need a seat to watch TV if that is deemed necessary
2021 Grey Wolf 26 DBH
2022 F250 Lariat 4wd Race Red 7.3 Godzilla
Formerly: 2019 F150 Lariat 3.5 EB 2wd Plat. White Max Tow
