Old 11-05-2016, 08:05 AM   #1
Winegard G2+ install
Have a 2017 Forest River Cardinal 3250 and trying to hookup the portable winegard G2+ from outside sat port to receiver inside coach, anyone know where other end of outside port terminates behind TV inside. Thanks
Scotrod106 is offline   Reply With Quote
Old 11-05-2016, 09:03 AM   #2
Left Coast
Why not pull the outside receptacle and identify the color of that coax, then pull the inside one and look for that same color.....
Old 11-05-2016, 09:29 AM   #3
No cover plate outside Bob, it's in the water valve cabinet. I may be able to pull the whole panel inside the cargo area to see in at the coax. Was hoping someone with a similar unit could point me to the other end of coax behind TV
Old 11-05-2016, 09:33 AM   #4
Left Coast
That would be the best, but, if that doesn't happen, I'd take a 50' coax and attach it to the outside connector and take the free end inside, and using an ohm meter, check all inside coax connections for continuity
Old 11-05-2016, 10:32 AM   #5
I may make a jumper and go inside to check continuity cuz don't have a 50' but I can't believe the dealer, direct tv, and winegard can't help. I understand that the two latter won't know how the RV is wired but the dealer not having this come up before? I'll try the manufacturer Monday if I can't locate. Thanks again
winegard
