Old 10-12-2020, 07:04 PM   #1
Holy cow, this canít be legit!
Found while scrolling through FB....
2017 Coachmen Apex Nano 193BHS
2017 Ford Explorer Platinum w/ Tow Package
SickPup404 is offline   Reply With Quote
Old 10-12-2020, 07:52 PM   #2
LizzyRN's Avatar
YIKES!
Liz
The NW corner of Washington state
2020 Flagstaff E-Pro 15TB
2006 Ford Expedition 4 x 4
LizzyRN is offline   Reply With Quote
Old 10-12-2020, 08:16 PM   #3
Attachment 241048
Serious question - why are the door and the awning on the wrong side?
-Qwkynuf
2003 F150 Supercab 4x4, tow pkg, 3.55 gears
2020 Flagstaff Micro Lite 21DS
Qwkynuf is offline   Reply With Quote
Old 10-12-2020, 08:17 PM   #4
Brake is on left
The Evil Twin's Avatar
Its British.
The Evil Twin is offline   Reply With Quote
Old 10-12-2020, 08:20 PM   #5
LizzyRN's Avatar
Maybe they are left handed? Or in the southern hemisphere?
Old 10-12-2020, 08:26 PM   #6
Jayhawker
Jayhawker's Avatar
More than likely they live in Australia, and like living on the edge! LOL
2018 Surveyor 243RBS
Jayhawker is offline   Reply With Quote
Old 10-12-2020, 08:46 PM   #7
Jayhawker
Jayhawker's Avatar
JAYCO motorhomes and trailers have been built in Australia since 1975. I never knew that until today!
Old 10-12-2020, 09:13 PM   #8
What could possibly go wrong?
"A wise man can change his mind. A fool never will."
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 10-12-2020, 09:39 PM   #9
For a while one time, we were without a camper, so I borrowed a 5vr. I had to take the wheels off one side to level side-to-side, because a darn sand dune had recently formed clear across the pad.
It took all the regular blocking just to make steps up the other side to enter. I had reserved all the spots and, of course, had to let other family avoid this snafu.
Wes
2019 Leprechaun 311FS
Wes, Linda & Quincy (std. Brown Poodle)
Wes Tausend is offline   Reply With Quote
Old 10-12-2020, 09:45 PM   #10
Best way to look for rips on the under belly liner, and lots of room to work.
TCedmon is offline   Reply With Quote
Old 10-13-2020, 07:38 AM   #11
PhD, Common Sense
My guess is that the photo is reversed. (Occamís Razor)
My serious question: How did he get it jacked up enough to even do that???
eye95 is offline   Reply With Quote
Old 10-13-2020, 08:02 AM   #12
Oaklevel's Avatar
Originally Posted by eye95 View Post
My guess is that the photo is reversed. (Occam’s Razor)
Anthing is possible, live around here for awile...................... that would not be unusual.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 10-13-2020, 08:13 AM   #13
I had to do something similar twice in the past. NOT as extreme, but, both times took extending tongue jack as far as possible, resetting using blocks, and jacking again. Not far from Virginia either time, Oaklevel. Once at Lake Gaston and once at Muddy Run in southern PA.
The Muddy Run occasion was a 5th, the Lake Gaston was a TT. I bought X chocks for the wheels, and assured the stabilizers were extended. Also advised wife, no sudden moves or exercising inside. Oh, and the 5th got a tripod stabilizer.
I have started looking for brake backing plates with the parking brake linkage for when the brakes have to be replaced.
2018 Surveyor 264RKLE
Retired
Location depends on weather and state plandemic rules.
Most coincidences are carefully planned
Jeffjeeptj is offline   Reply With Quote
Old 10-13-2020, 09:39 AM   #14
If it was reversed the lettering on the trailer would be backwards. It's probably in Australia or the UK.
In fact, here's the exact model on the Australian Jayco website.
https://www.jayco.com.au/range/carav...erline-caravan
Iwritecode is offline   Reply With Quote
Old 10-13-2020, 09:45 AM   #15
Boss Ox & Drovergirl
oxcamper's Avatar
Even bigger question:
How's he gonna get it down?
Mark, Vicki, & Scout THE dog
2015 Hemisphere 282RK
2011 2500HD Silverado
1992 Goldwing Aspencade
oxcamper is offline   Reply With Quote
Old 10-13-2020, 09:55 AM   #16
The exact opposite way they got it up there.
It takes some time and patience but basically you have to:
1. jack up the trailer
2.put blocks down under the trailer
3. lower the jack and take it out so that the trailer is resting on the blocks.
4. put blocks under the jack to raise it higher
5. jack up the trailer some more
6. add more blocks under trailer
7. repeat as needed
Old 10-14-2020, 09:29 AM   #17
rbq
Jenga for RV's.
2014 Chevy Silverado
2011 Rockwood Roo 233S
rbq is offline   Reply With Quote
Old 10-14-2020, 09:51 AM   #18
When I was a kid it was common to lift houses up as much as a full story and then build the "ground floor" under it. That's how people took their small "Pre-War" houses large enough for their "Baby Boom" families. Just jack a foot or two, build cribbing, lower onto cribbing, move jack support up and repeat.
I wonder how his HOA views this? Mine would have a cow.
2004 Nissan Titan
Old 10-14-2020, 10:00 AM   #19
I especially like what appears to be a chain through the wheels (higher in the front wheel to lower in the rear wheel) to keep the wheels from turning.
Also 'appears' they are watering the tree with grey water... or whatever.
Brilliant!... here... hold my beer!
Days Camped: '18=51 '19=58 '20=110 '21=21
Old 10-14-2020, 10:09 AM   #20
wmtire's Avatar
Not saying that's what's it used for, considering how unsafe it appears....but if it was my mother-in-law, I understand
2011 Flagstaff 831 RLBSS
I often say to myself, "I can't believe that cloning machine worked."
