01-12-2021, 02:59 PM
#61
anderson levelers
If you are speaking of the Anderson wedges that go from 1" to 4"...they are great. They allow leveling to be a smooth occurence. Using my level gauge on the front of my 5th wheel, I place the levelers in front or back of the tires and slowly back or pull the 5th wheel to where the gauge shows it at level. I put on the brakes, squeeze the trailer brakes and set the parking brake in my PU. I then put the included wedges as needed behind or in front of the tires. They are well worth the money. Anderson also stands behind their product as I had one crack through for some reason. I contacted them with a photo and they send a new wedge.
01-12-2021, 03:39 PM
#62
We have them and while we don’t use them often, when we need them they are great.
"There comes a time in every man's life, and I've seen plenty of them." Casey Stengel
"Red" my 2018 Ford Lariat F-150 4X4 W/ Max Tow pkg
"Rover" our 2018 Forest River Wildwood X-Lite 241qbxl
01-12-2021, 03:57 PM
#63
I have not used the Anderson levelers but purchased the CARMTEK Levelers. they are the same concept but less expensive. i love them, easy to use.
01-12-2021, 06:06 PM
#64
Originally Posted by LarryB.
After looking at several types of leveling "systems", I opted to use rubber pavers in place of leveling blocks. ...
Are they not heavy?
- 2016 Ford F-150 SCrew Lariat 4x2 3.5L Ecoboost, 1700# payload
- 2020 Rockwood 2507S
01-12-2021, 06:10 PM
#65
Being prompted to search for these by your reference to them, I see they're rubber coated and have ridges on the bottom, which probably helps with slipping. Can you comment on your experience in that respect?
#66
Anderson levelers
I bought a combination set. It has the levels and it has the jack wedge. They all work great.
01-12-2021, 06:20 PM
#67
The CARMTEC levelers have a rubber type feel to them and the ridges do help to keep the wedge locked in place. I have found that in some instances you need to put a rubber mat underneath to keep them from slipping on smooth surface. Easy to use and quick set up
01-12-2021, 06:59 PM
#68
I have only used my once or twice. I see where that could happen.
01-12-2021, 09:22 PM
#69
Originally Posted by Ron.danahy
Do you ever find the need to carry any additional blocks with you?
Take a couple of 2x6x3' just in case the soil is soft. They will sink.
01-13-2021, 04:23 AM
#70
No I have not thought about it. Good idea. Thanks
01-13-2021, 02:28 PM
#71
Originally Posted by Hawk on the Wing
I use them and haven't seen anything else I think I would like better but I have a solution that eliminated a couple problems I saw.
The first issue is using them on gravel or worse which didn't seem good for them. I say worse because I am primarily a back country boondocker. That also often gets me into ground that needs some extra lift. And I was also sometimes having a weird thing happen on hard surfaces where I would roll up and hit the brake to hold that position and the tires would spit out the wedge.
To solve all these problems I got a mud flap at NAPA and cut it to fit a 24" 2x6 with 45 degree miters on the ends. I then glued the mud flap piece to the 2x6 with contact cement. So unless I need very little lift I put the Anderson on the 2x6 and it's easy on the wedge, gives a little extra height, and prevents the wedge from spitting out.
Has anybody had that problem with the wedge getting spit out?
Hey guys, I posted this earlier. Check how I build a 2x6 pad for this slipping problem and keeping them from getting broken on rough ground.
NoBo 16.8 with F.J. Cruiser
01-13-2021, 02:59 PM
#72
We used the Anderson system for 2-3 years then one broke. I think the sun got to it. Our camper stays put all summer. It certainly wasn't weight, we're <4k lbs fully loaded.
We've switched to the Beach Lanes. They seem a little heavier. So far so good.
2016 Rockwood A213HW
2019 GMC Sierra Crew Cab Denali 6.2
Craig
01-13-2021, 05:33 PM
#73
Best thing I bought for leveling. Yet to break one in six years of heavy use.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2021: 35 nights already booked so far
01-14-2021, 03:36 PM
#74
Second an earlier suggestion for Beech Lane
Someone mentioned Beech Lane earlier. I have seen comments from Boondockers and full time Rvers about breakage of Anderson Levelers and sinking in certain soil conditions. The Beech Lane does look A LOT more robust over Anderson and has longer warranty. Unfortunately not US made. But that will be my choice along with some 2x6x4'.
https://www.amazon.com/Beech-Lane-Ca...ct_top?ie=UTF8
