I have seen wall mount brackets that have a permanent metal plate that mounted on the wall and the fold up couch has a bracket that can slide into the wall plate. I am trying to come up with a solution to remove 1 of my rear couches to allow a rzr to fit in my toy hauler.
I am trying to find a bracket like this that I can install on my couch but I am having trouble finding anything. Has anyone done a conversion to these brackets or able to give another solution to being able to easily remove the couch. Thanks for any suggestions.
I want to use it stilll as I need the sleeping space. I have a friend with factory brackets that are removable in his older trailer. I figured there must be something out there.
You could probably have something fabricated similar to how the tv mount works with it. You'd just need that on the wall side. Probably even do it yourself with thin enough metal and the right tools, just hammer some lips into it
