Old 07-22-2024, 09:46 PM   #1
Squeaky Floor above where my freshwater tank is located
Hello my 2006 Forest River Sierra T23SP Toy Hauler - 26 FT floor squeaks right over area where the freshwater tank is located which I suspect bowed upwards when the tank was overfilled. I am trying to figure how to stop the squeaky floor and looking for tips from others you have experienced similar situations. I plan to drop the 50 gallon freshwater tank but what is the best way to brace the existing floor that lays over the water tank and what are the best materials to use to do the job correctly? Thank you.
Timothy is offline   Reply With Quote
Old 07-22-2024, 11:02 PM   #2
Best way is to open the underbelly and see where you can install wood or metal bracing. I have used angle iron and/or wood 2x stock with aluminum brackets to solve this problem.
Have someone step on the spot u mark on the floor while you are underneath so you can see the floor flex. You may have to remove the tank to brace the floor.
2016 RAM 3500 DRW 4x4 LB LoneStar, w/RDS 33Gal Aux tank, Timbrens, Andersen Ultimate2, SwiftHitch SH04
2018 Chaparral 360IBL w/TST507 TPMS, Lippert GC3 Autolevel, Furrion Backup Cam, Progressive HW50C, RV Airflow
chaps2018 is offline   Reply With Quote
cat, floor, tank, water, water tank
