07-15-2020, 07:21 AM
toy hauler, zippered screen panel
I have a 2019 Forest River Wildwood FSX 260RT toy hauler. I am looking for a part number or a supplier for the zippered screen panel used to cover the back opening of the unit.
Thank you in advance
07-15-2020, 07:36 AM
Best thing to do is contact your dealer.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
07-15-2020, 08:09 AM
If you need to replace or add one I would look at the magnetic or retractable units.
07-18-2020, 06:33 AM
Following, dealership crush the zipper slider with the ramp hinge on brand new 2020 Salem 190rt. Haven’t been able to use the camper since our purchase date of 20 June.
2020 SALEM FSX 190RT (Toy Hauler)
2019 Chevy Tahoe LS 4x4 w/max trailering package
2021 Ram 2500, 6.4Hemi, tow package
07-18-2020, 11:26 AM
I have same issue, we use the trailer anyway. Just can't use the back door as a patio. Have not been able to find a replacement screen, yet.
07-23-2020, 12:39 PM
Have you tried Forest River? I was looking for one for out GeoPro and was able to get the part number and price from Forest River.
...ron
2022 Georgetown GT5 31L5
2013 Ford Edge Limited
07-23-2020, 01:56 PM
Thanks, did you reach them through their web site?
07-27-2020, 06:24 PM
I ordered an after market zipper slider that screws together to fix my issue. Dealership told me the screens are custom made for the units. Which would explain why it’s hard to find a part number. I got tired of waiting for warranty repair which is only going to get worse and longer with the flood in sales. I also cancelled the 5 year extended warranty I purchased for $3,500 during sale for the same reason.
07-28-2020, 10:06 AM
Thank you. I found a replacement zipper pull at Zipper Shipper Sewing Supplies and have not had time to find out how well that works. Your zipper slider that screws together sounds like a better idea. It makes sense that the screens are custom made. However, it makes it harder for anyone to get a replacement.
Thank you again
07-28-2020, 11:42 AM
Thank you again
I too have tried the replacement zipper slider from that manufacturer since it came with a pull tab on either side and is a perfect match. I couldn't get the zipper on without damaging the fine nylon coil teeth of the zipper since both ends of the zipper are sewn under fabric. What ended up working was the AceCamp FixnZip Zipper Repair- Black Nickel 1/4” to 5/16” Tooth and Coil Zippers from etrailer.com Code 3777065. $12.85 + $5 shipping. Not a cheap zipper slider. It comes with one tiny pull cord but there is a hole on the opposite side to attach another pull cord. Once on i had to manually feed the teeth together for maybe about 1/2” as far into the end of the zipper i could go that is sewn into the fabric on the ends. Once i did that it works like it should. I wouldnt try forcing the zipper you purchased onto the nylon coil teeth, once the coils are ruined they will never work the same. I know from experience. Thankfully i tried it at the very bottom of the screen. Only correct way to get that slider you purchased on would be to unstitch the fabric on the top or bottom of the screen and feed on the slider then restitch the fabric.
07-28-2020, 01:22 PM
If you are still under warrantee call forest river warrantee. They will send a new one. I had this happen on my first Grey Wolf.
2019 Puma XLE 27QBC Toy Hauler
2005 Honda VTX 1300
2002 Goldwing 1800GL CSC Trike
2020 Ram 2500 Crew cab 6.5 bed
Ron & Shirley (Empty Nesters)
07-28-2020, 04:29 PM
Yes! I have filed my under the 1 year warranty, I just didn't want to wait months for it to get ordered/processed/shipped. I was able to fix the stock one for the time being with the aftermarket zipper slider. This way I should eventually have 2 screens once all is said and done. If they need the broken screen turned in, I'm fine with that. I can take the aftermarket slider off. Good looking out though! much appreciated. I'm guessing if the magnets holding the screen are not pushed up against the ceiling, with the screen closed and slider all the way down it has the potential to get stuck in the ramp hinge when closing up the ramp.
