2019 f250 diesel with E rated good year tires
Is this a crew cab? A 4wd? A reg cab? A long bed? A short bed? Lifted? Surely you can give a better TV description?
Hate to assume but are ALL tires inflated to max cold PSI? Does the trailer have garbage china bombs? Are you using dual sway controls on both sides of trailer? Has the trailer suspension been checked for any problems?
First. I suggest you get very acquainted with your local truck scale.
Get your trucks axle weights.
Get your unloaded combination weight and weight on each axle.
Get your loaded combination weight and weight on each axle.
Be sure and properly set up the WDH and dual sway control bars. Load the front trailer compartments with all your extras. I bring extra propane tanks, spare tire, spare parts, and many tools, all in the front compartment.
Load the Razor as far forward as possible.
Can you post a pic of your loaded combination?
