Old 01-28-2020, 06:16 PM   #1
correct track recall
took my 5th in for recall for spring hanger nuts backing off in October 2018. all good they said!!!!
pulled from Wisconsin to Texas November 2019 and while repacking bearings noticed that one of the recall nuts had come off. Also lost the cam plate on the inside for correct track adjustment.
So the point is, don't trust bad assembly parts ever.
half work half play is offline   Reply With Quote
Old 01-29-2020, 09:35 AM   #2
SeaDog's Avatar
welcome to the forum its a great place to get your questions answered. I would think a better point to make would be inspect your suspension on a regular basis especially if there has been a recall. good you found the problem before something fell apart. How did you correct the problem so it wouldn't happen again. what rig do you have?
Retired Navy
2016 Flagstaff 26 FKWS
recall
