Old 03-23-2023, 12:39 PM   #1
Relays
Has anyone had a problem relay in fuse panel in engine compartment Chevy 4500 2014
sunseeker5 is offline   Reply With Quote
Old 03-23-2023, 02:02 PM   #2
bikendan's Avatar
Moved thread from the RV Industry/Recalls/Service Bulletins sub-forum to the Forester and Sunseeker sub-forum.
Sent from my SM-G781U using Forest River Forums mobile app
Old 03-23-2023, 02:22 PM   #3
They do fail..
Automotive relays do fail from time to time. Fortunately, GM only uses two or three different types on the vehicle.
My son's trick is to swap the suspect relay with another one that has the same part number from a non-critical circuit, e.g., the rear window wiper or washer. If the original problem is fixed and the new area has stopped working, the question is answered.
The relay location/functions appear in the fuse maps in your owner's manual.
These relays are available at all the auto parts stores.
Larry
Larry-NC is offline   Reply With Quote
Old 03-23-2023, 04:05 PM   #4
Certified Curmudgeon
Vanilla
You might want to elaborate as to exactly what the problem is. i.e. intermittent starting, dash goes blank ect. Consider that the problem may not be the relay itself.
Mike Dropped
