Old 05-14-2024, 01:57 PM   #1
Tire Pressure Monitor Sensor Malfunction
My wife and I purchased our first RV. We purchased a 2023 Leprechaun 230FS.
The tire pressure sensor indictors come on after 30 minutes of drive time ever since we took possession of it. I returned this RV the next day to the service dept. to repair this problem and a other problem with the slide. Slide was fixed but the TPMS's are an on going issue.
The dealership has given up, and point us to Ford, they have done everything they could and have contacted their engineering people with this issue, and we're waiting for their response.
I contacted Coachman and they say it's their understanding that there is an interference issue between the TPMS and possibly the radio they installed.
Has anyone else with this make, model on a E450 Ford chassis experienced this problem.
Thanks!
RB2004 is offline   Reply With Quote
Old 05-15-2024, 06:08 AM   #2
TMPS sensors are activated, or by movement, or by 133mhz signal from the receving unit with display.
I think yours is the second.
Then signal is not send by unit or some disturbance.
Do all the wheels react that slow, or only rear.
Then it could be a distance problem like traveltrailers often have.
jadatis is offline   Reply With Quote
Old 05-15-2024, 02:19 PM   #3
Hello,
Yes I agree with the second one, and yes all 6 of 6. Information screen will state "Tire pressure sensor fault" with the tire image lit up.
I'm waiting for Ford to get back to me on their thoughts on this issue.
I was wondering if anyone else out there had this problem with their Class C from Coachman?
Thanks for your reply!
Old 05-15-2024, 02:35 PM   #4
Then I think I undersood wrong.
Thought the pressures where only given after 30 minutes driving.
But now I make if your post, that tmps works in the beginning, but fails afted 30 minutes drive.
Old 05-15-2024, 03:09 PM   #5
Correct.
After 30 minutes of driving the information screen makes the statement and the tire icon lights up.
Ford & the RV dealership with Coachman assistance have tried to reset but the system just won't respond and correct.
Going to wait for Ford's engineering people to find a solution and if they can't see what the options are after that.
Thanks again!!
Old 05-16-2024, 01:12 AM   #6
Some sugestions
Unit side
Software bug> needs update.
Not repeating 133mhz starting signal so sensors go back to sleep after a while.
The already mentioned disturbance.
Sensors side
Almost empty battery so in begining enaugh volts, but to low voltage after a while (30 minutes)
Would it be possible to, yust as for carsystems, to read out the errorcodes?
monitor, pressure, tire
