If you NEED the deck, the SSL is the way to go. If you only think you need it, don't buy one.
I had a SSL when we used to run ATVs. it was fantastic for that. Once we got out of ATVs and went to side-by-sides, we couldn't use the deck any more, except to haul things that I could have put in the back of the truck.
The #1 disadvantage is an SSL pulls at highway speeds like it weights 15,000 pounds. Its like towing an open parachute. Also, its just a 21SS with another 8 feet welded onto the front. The axles don't get relocated. So it and extremely long distance between the hitch and the axles. Getting in/out of tight spots is nearly impossible.
Tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
"Camper" 2016 Rockwood Signature Ultralite 8329ss
"Casper" 2017 Ram 2500 Laramie Diesel
..ProPride 3P Hitch - "Yeah. It's worth it."
