Old 10-23-2019, 10:25 AM   #1
Checking roof sealing
I have a 2019 Rockwood Roo 233S I purchased last year. I have looked at the sealing around the roof several times and everything has been good. I just checked it before getting it ready for winter and noticed between the roof material and the gutter there is a very small bead of caulk between the two. In several spots the 2 have come apart and creating a crack in the caulk. I'm not sure how the roof is sealed below this spot. What would be the suggested fix for this? Do I use Eternabond tape there or can I just clean up the caulk and put a new bead down (of what)? The issue with the tape is the ability to get a good seal in the gutter because the gap is so small. It is weird how thin the caulk is between this which got me thinking is this just to prevent water dripping between the gutter and the siding?
ID:	217885   Click image for larger version
2019 ROO 233S
2017 Dodge Ram 1500 Laramie
Wisconsin-1 is offline   Reply With Quote
Old 10-23-2019, 10:55 AM   #2
I sealed all that up on mine with Enternabond tape.
Mike
Mike Gray
Forest River Wildwood
2018 230BHXL
2015 Sierra SLE 5.3 V8 4x4
Mike223 is offline   Reply With Quote
Old 10-23-2019, 02:30 PM   #3
Did you remove the old caulk? The only thing I would be afraid of is how thin the caulk is that I would rip or damage the roofing material. Did you go with the 2" or 4" tape? Thanks
2019 ROO 233S
Old 10-23-2019, 02:41 PM   #4
I had same situation on mine. Dirt makes it look like its cracking. I wiped it down with mineral spirits and found it to be ok!
2018 Flagstaff Super Lite 29RKWS
2015 F 150 max tow
Where ever you go there you are
grumpyer is offline   Reply With Quote
Old 10-23-2019, 02:43 PM   #5
BTW....looks awful dirty for the age of it!
2015 F 150 max tow
Old 01-09-2020, 09:50 AM   #6
yetavon's Avatar
Our 2015 has split at the same spot....eternal bond to the rescue
2015 Shamrock 21DK
2005 Silverado Ext cab
Nights camped 2019.....all of Em...Homes a 2001 Sea Breeze 36' 5 ER
yetavon is offline   Reply With Quote
check, roo, roof, seal
