Old 01-18-2019, 10:53 AM   #1
n4uaj's Avatar
Range hood fan and light
Iíve got a 2014 Shamrock 183. The fan and light over the stove has stopped working. A black wire carrying power to the light switch with a jumper powering the fan switch has power. Both switches have power out. Power is present at the light bulb socket. The white ground wires from the light and fan go to a connector with green wire out to ground on the hood. One more white wire also connects to this ground connection. Anyone here run in to a problem like this? Iím thinking it has to be a bad ground somewhere for neither one to work.
Bill
2014 Shamrock 183
1995 Chevy Silverado
n4uaj is offline   Reply With Quote
Old 01-18-2019, 02:15 PM   #2
Head Rambler
How did you determine that there was power at the switches?
If you put the test leads between the positive and negative leads before the switches, is there ~12 volts present?
Gotta go campin!
Old 01-18-2019, 02:43 PM   #3
Commercial Member
ES_FR's Avatar
n4uaj,
We would be happy to assist you with your 2014 Flagstaff Shamrock. Because your ongoing satisfaction is very important to us, we invite you to contact Rayna Dimitroff in our Customer service department through the following personalized and direct link: Forest River RV Direct Service Contact - Forest River, Inc..
This direct link is provided for your convenience in order that we may resolve your concerns as quickly as possible. We will strive to respond to you within 24 hours of receiving your correspondence.
Respectfully,
Forest River
ES_FR is offline   Reply With Quote
Old 01-18-2019, 04:08 PM   #4
n4uaj's Avatar
Iíve got a test light from my school bus mechanic days. It lights up.
Bill
2014 Shamrock 183
Old 01-18-2019, 05:08 PM   #5
Head Rambler
It has to have a positive and a negative to connect to, right?
That makes me believe that the negative is there, but maybe there's a connection issue somewhere. Either that, or you have two items that are both bad.
Gotta go campin!
Old 01-19-2019, 04:08 PM   #6
AKA: 'tiredTeacher
awellis3's Avatar
..., or you have two items that are both bad.
Highly unlikely BUT still possible.
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
Old 01-19-2019, 04:13 PM   #7
AKA: 'tiredTeacher
awellis3's Avatar
Remove the bulb. Hook the alligator jumper from your test light to the range light's negative terminal. If the test light lights when you touch the point to the hot side, the ground is good and you're getting juice. That leaves the bulb as the culprit. Do the same with the vent fan.
Wright and Penny
Richmond, Va.
Old 01-19-2019, 04:16 PM   #8
RY3
On my range hood in my Coachmen the light was working but the fan not working. I took apart and there was an inline fuse soldered to a wire inside the unit that was bad. I replaced the fuse with an replaceable fuse and holder.
RY3 is offline   Reply With Quote
Old 01-19-2019, 05:00 PM   #9
cavie's Avatar
Clip the negative of the test light to the supply white wire and leave it there. If you have voltage at the switch then follow the switch wire about 18" to the fan. Any power there? There should be no connection of any kind between the switch and the fan motor. Or the switch and the light. If you have power then remove the tester from the white wire and connect it to the motor negative wire. If you lose power you have a break in the negative connection. The negative connection should have three wires there. Power negative, fan, and light. Possibly a 4th going to another device like the Furnace, fridge control circuits.
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 01-20-2019, 11:39 PM   #10
I always test the bulb first.
aircommuter is online now   Reply With Quote
Old 01-30-2019, 09:22 PM   #11
n4uaj's Avatar
After getting in there and pulling and wiggling the wires, it started working and so far I canít make them quit again. I think the ground was somehow pinched under the board the microwave sits on and when it pulled free everything was good again.
Bill
2014 Shamrock 183
Old 01-30-2019, 09:27 PM   #12
Georgia Rally Coordinator
aceinspp's Avatar
Mine does it once in a while I just bang on the hood and all starts working again. Later RJD
2020 Shasta Phoenix SPF 27RKSS
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
Days camped 2020 5
Old 07-02-2019, 07:43 PM   #13
rlh1957's Avatar
Cheap switches and light sockets.
2018 Forest River Rockwood Roo
24WS
2019 Ford SD F-350 SRW Lariat
Tow & Gooseneck Prep
FX4 Off Road (4X4)
rlh1957 is offline   Reply With Quote
fan, light
