Roo Bunk Leaks
My 2011 Roo 21SS has been having minor leaks at the front bunk (no leaks on rear bunk), which appears to be a normal occurrence that folks are experiencing. Read numerous threads, and watched some YouTube videos. Mine already has the weatherstripping along the outside edge of the bunk sealing the flat of the bunk to the frame. I pulled the frame screws, countersunk them, reinstalled them, and caulked around them as well as inside the philips to create a more flush surface. I also pulled the squished pads on the latches and added a tad thicker, and much firmer pads to close the seal tighter. All of this, and I am still getting a leak from ABOVE the frame (between the wood shelf above the white metal frame inside and the white metal frame itself). It leaks above the frame, then runs along and eventually drips out down the interior of the folded up canvas. Has anybody had a similar leak location, and had luck tracking down where it is coming from? There is a bead of silicone already between the aluminum frame and the gutter on the exterior, but it is original and looks dirty and worn, although still pliable and does not appear to be compromised. Debating scraping it all out and reapplying. Attaching a few photos to help explain. Any help would be helpful!
- 2011 Rockwood Roo 21SS
- 2015 Toyota 4Runner Trail Premium
