Old 10-25-2020, 10:11 AM   #1
LyS
Old Camper but newbie RV
Winterizing problem
Hi folks,
So our first time winterizing our 2019 Roo, so we paid a guy to help us learn how to do it. Ran into a problem that the guy couldn't solve, hoping for some insight from this great community. When he was running the antifreeze through the inlet valve, found that antifreeze ended up in the fresh water tank. The guy basically said that was "going backwards" but could figure out why that was happening. Any thoughts?
LyS is offline   Reply With Quote
Old 10-25-2020, 10:15 AM   #2
Brake is on left
The Evil Twin's Avatar
Through what inet valve? The city water connection or winterization line? It almost sounds like he was using the city connection and the water pump check valve did not seat.
The Evil Twin is offline   Reply With Quote
Old 10-25-2020, 10:19 AM   #3
LyS
He must have been using the winterizing valve as it did work to fill the hot and cold lines (it came through the low point drains).
Old 10-25-2020, 10:22 AM   #4
need pic of valve set up. w/ heater rear and overall pic of lines. this sounds impossible. intake before pump
Thomas ho is offline   Reply With Quote
Old 10-25-2020, 10:27 AM   #5
LyS
That's what the guy said as well. Didn't make sense. Will try to post a pic. Not at the TT at the moment. Wonderful husband wonders if the guy did use the wrong valve and was covering for himself?
Old 10-25-2020, 10:35 AM   #6
LyS
Here are some pics that hubby had on his phone
ID:	241851   Click image for larger version
winter, winterizing
