10-21-2020, 10:29 AM
MWR facilities for service connected disability
My nephew, who is retired army, recently informed me that most military installations with famcamps or campgrounds are now open to any vet with 0%-100% service connected disability.
Previously, I had understood that these campgrounds were only open to active duty, retired, or 100% disabled.
Anyone here used this to camp on any base campgrounds?
2016 F350 CC Dually Powerstroke 4x4
2014 Cedar Creek 34RLSA w/Level Up
2007 HD Ultra Classic 103
USS Pyro AE-24 WestPac MM2 '71-'75
10-23-2020, 05:18 PM
Nephew is correct, 0-100% qualifies one to use those facilities.My question is, how do I get an if card for my wife; I have VHIC card?
10-23-2020, 05:35 PM
Part-Time Campground Host
If you already have an VHIC card your wife doesn't need one. She can pass almost any gate with her Driver's License.
Craig & Cath
Days camped since 2015(retirement): 1659
10-23-2020, 05:38 PM
PhD, Common Sense
VHICs do not allow for family member benefits. Those members would have to qualify in their own rights.
On many bases and posts, you wife will be able to enter the installation and use some facilities as your guest. She won’t be able to shop in AAFES or commissary stores. She can accompany you, but you have to do the shopping. I won’t speak for other exchanges apart from AAFES.
Don’t forget to sign up for online shopping benefits and the Star card. Also, if your wife is a veteran (even without service connected disability), she qualifies to shop online.
10-23-2020, 06:03 PM
Actually, from everything I've seen, a spouse that is not a certified caregiver has to get a pass at the visitor center every time they come on base. And they need to have Real ID compliant ID.
2019 Silverado LTZ 1500 6.2L 10 Speed 3.42 Max Trailering Package
2018 Freedom Express 192RBS
2022 Highland Ridge Open Air Lite Range 17BH
10-23-2020, 06:31 PM
PhD, Common Sense
True that a Real ID compliant ID is required for guest access to military installations, but not all installations require visitor passes for those who do not have a military ID, a VHIC, or some other ID that grants access to military installations.
At Wright-Patt, for example, if one person in the car has a military ID, the remaining occupants can produce a Real ID to allow them to accompany the military ID holder.
10-24-2020, 12:27 PM
Don
MWR Facilities
You don’t have to be disabled to use MWR facilities just retired military. I’ve used them all over the USA and never had to prove disability. Just used my Retired ID.
10-24-2020, 12:55 PM
Me thinks you have missed what this thread is about.
10-24-2020, 02:08 PM
I’m 100% disabled combat vet and have used the installation CGs at times. Easy access as both wife and I have DOD IDs. Some are great, some ok, and others not so much. Some are gorgeous 1st come and maybe you get a spot. Some have permanent campers although not supposed to. Youngstown ang has a rather new CG with 5 pull through sites. 3 are taken with 100# propane tanks. If going to Biloxi area Gulfport Navy CG works better than the bigger AFBase but us the AF commissary and exchange. Some are not on the base itself. Better selection west of the MS. Other favorites are ——-.
10-24-2020, 04:38 PM
PhD, Common Sense
The “service connected” VHIC gives veterans who have not retired access to exchange, commissary, and retail MWR facilities. There are a large number of veterans in this category who would not otherwise have access. This change occurred within the last year.
I serve numerous customers with a VHIC and no military ID.
10-24-2020, 05:43 PM
Veteran?
In this context does "veteran" mean "retired" or does it include anyone with a few years' service and an honorable discharge. This term is confusingly used both ways.
I served for two years and three days, 1971-1973, active duty, two years actve reserve, and two years inactive reserve.
Lowe's gives me a Veterans' discount. They accepted my DD-214.
Advance Auto offers a Veterans' discount, but in the fine print, it's restricted to Active and Retired military.
I have always assumed I did not have access to base exchanges, commissaries, VA hospitals, or campgrounds. Have I been missing out on something?
Larry
10-24-2020, 08:19 PM
Veteran means you have a DD-214. The shopping at the Exchange and Commissary are new in the last few years. The use of the RV parks by Veterans with service connected disability is also recent.
If you have health problems that started while you were on active duty you may be eligible for service connected disability rating. You would need to apply to the VA for that certification. There should be a Veteran’s advocate office in your county, check with them for assistance.
(Previous) Coachmen Mirada Select 37RB
(Previous) Coachmen Freedom Express 246RKS
(Current)2022 Grand Design Reflection150 226RK
2022 F150 Powerboost Hybrid.
10-24-2020, 11:02 PM
The expanded eligibility for certain Veterans to access military commissaries, exchanges and MWR facilities was effective Jan. 1, 2020:
https://www.blogs.va.gov/VAntage/684...nd-mwr-access/
Quick guide to eligibility for VA healthcare here:
https://www.va.gov/health-care/eligibility/
My S.O. has used her Veterans Health Insurance Card to access facilities at several bases including MCB Quantico, Va., and Fort Benning, Ga. Gate security personnel were all aware of the rule change.
2017 Cherokee Grey Wolf 25RL
2017 Nissan Titan 4x4
10-25-2020, 07:16 AM
PhD, Common Sense
You are a veteran for the purposes discussed in this thread.
Check to see if you have a service-connected disability (even as low as 0%). If you do, you qualify for a VHIC card with the “service connected” endorsement. That will give you access to all of the privileges we are discussing in this thread.
Even if you do not qualify for the VHIC with the endorsement, you can still shop online at exchange websites, including www.shopmyexchange.com (the AAFES site) and you can still qualify for a Star card.
My understanding is that the goal is to eventually extend all of these privileges to all veterans with general or honorable discharges.
10-25-2020, 09:33 AM
Doug, thanks for the clarification.
It's good news that I have no service-connected disability. In fact, I am in excellent health. I hike, snorkel, and cycle, use ladders, and just finished rebuilding a 50-foot deck including wrestling with 80-lb 16' treated 2x8s. Not bad for a 75-year-old.
I won't fret about the other benefits--the nearest Exchange and Commissary are at Ft. Bragg, about 90 minutes away, and the DIL tells me that Walmart is usually cheaper.
Larry
