Originally Posted by jamcoro
I might change the handle as with the extra weight, it might be too much for the plastic handle.
Good idea with the gas struts for the overhead doors. Really wish the manufacturer took care of some of those small features.
Centering the handle on the WEIGHT you are lifting is a huge help.
Factory mattress would catch on the headboard storage & the whole bed would twist when lifting.
The way the bed framing is designed, you may not be able to add extra supports and just have to replace with stronger ones.
When mounting struts on the overhead doors, add a backing wood piece to the cabinet frame where the strut will attach. I didn’t, figuring two out of the three screw mounting points would hold adaquately. It didn’t, pulling out of the presswood frame.
2019 Cherokee Wolf Pup 16BHS flipped axle, 5K springs, 400AH LiFePO4, 3K inverter, 400 watts CIGS solar
2019 Ford F-150 S-Crew 5.5 bed V8 w/tow package, ITBC, Tow Mirrors, 3.55, SumoSprings, 7000# GVWR, 1990#CC
Husky Centerline TS WDH 400-600# spring bars
