Old 10-29-2020, 04:06 PM   #1
Domer
Best Air Compressor
I'm looking for recommendations on the best portable RV air compressor to inflate tires, but also to blow out water lines for winterization. From what I've read, the maximum PSI for blowing out the water lines is 30-50 PSI, so I'm thinking the compressor should have a regulator to limit the output. Thoughts?
Domer1972 is offline   Reply With Quote
Old 10-29-2020, 04:47 PM   #2
dcheatwood's Avatar
Viair
2018 Forester 3011 DS
Old 10-29-2020, 05:53 PM   #3
JoePa77's Avatar
I have the VIAir compressor that works for the tires and with an additional regulator and blow out plug a can use it for winterization too. This works well for me and my motorhome.
2020 Forest River Forester 2861DS
JoePa77 is offline   Reply With Quote
Old 10-29-2020, 06:10 PM   #4
SailorSam20500's Avatar
Another happy Viar owner. Compact and powerful.
When winterizing, I open a faucet before releasing air. Haven't bothered with a regulator. I do have a ball valve on the hose I use to connect the pump to the trailer which I open and close as needed. I do get a lot of exercise when blowing out the lines...
Al
Save the Earth. Itís the only known planet with Beer.
There are times where my greatest accomplishment is keeping my mouth shut...
S.E. Mich. Flagstaff 26FKWS / 2019 F-150 3.5 EcoBoost SCrew Propride
SailorSam20500 is offline   Reply With Quote
Old 10-29-2020, 10:02 PM   #5
Nothing works better for winterization than a standard air compressor with at least a 20 or 30 gallon tank. The small tire filler compressors simply can't push the needed volume of air needed for blowing out water lines.
2019 Silverado LTZ 1500 6.2L 3.42 Max Trailering Package
2018 Freedom Express 192RBS
2016 Silverado LTZ 1500 5.3L 3.42
2015 Jeep Wrangler Rubicon 3.6L 4.10
2020 KZ 130RBSE
AlaskaErik is offline   Reply With Quote
Old 10-29-2020, 10:14 PM   #6
Brake is on left
The Evil Twin's Avatar
Just picked up the Milwaukee 18v cordless. Its pricey, but no cords or generator needed. Portable and it will inflate the TT tires to 110 without a thought.
The Evil Twin is offline   Reply With Quote
Old 10-30-2020, 09:45 AM   #7
Jim34RL's Avatar
I carry a Dewalt 6 gallon pancake, 165PSI, 110V/115V portable air compressor with 30 feet of air hose. This is carried in my front basement compartment of the 5er.
Since I only stay at full hook-up sites this dose not present a problem for electrical power. I can adjust the air pressure so, I can inflate any toys or tires as require using the proper air pressure.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 135K+miles
