Old 04-06-2013, 06:45 PM   #1
bolted pads to stabilizer jacks
I had some left over Trex decking that I cut into 11" long pieces. Bolted to my stabilizers with 3/8" galvanized carriage bolts. Hopefully they will spread the weight and add a little more stability. This stuff is very strong, rot resistant etc. (composite plastic/wood decking)
boatnut is offline   Reply With Quote
Old 04-06-2013, 06:48 PM   #2
spierce617's Avatar
Very nice idea. I may do this. I currently use a 4X6 18 inches long under the jack to distribute the weight.
2005 Winnebago Adventurer 38R
Workhorse 8.1/Allison Transmission
Old 2005 Forest River Cherokee Lite 28A
spierce617 is offline   Reply With Quote
Old 04-06-2013, 06:56 PM   #3
jonnys_walkers's Avatar
Good idea.
Never enough camping!!
jonnys_walkers is offline   Reply With Quote
Old 04-06-2013, 07:34 PM   #4
Have run these 2 x 10 x 14's bolted to the jack pads for the last 7 yrs and they sure help. I have them on the front landing jacks also. Removed them from our old trailer and installed them on our 5ver.
ID:	27259   Click image for larger version
Old 04-06-2013, 08:13 PM   #5
Phat Phrog Stunt Crew
elind's Avatar
OC, Do the stablizer arms on your 5ver work? My Lacrosse rocks all over the place. Even the 20 lb dog shakes it. I was going to get wheel lock chocks, but I have wide spread axles. Theses are pricey but would it work instead. Or should spend a little more for the set up you have with bars?
2014 Wildcat 327ck
elind is offline   Reply With Quote
Old 04-06-2013, 09:37 PM   #6
I made my stabilizer bars and they do work. I also took the stab jack flat bar arms off (4) and replaced with 3/4" pipe braces. (heated, flattened & drilled the ends) Much stronger and took the wobble out of the rear stab jacks. I have side to side stabilizer bars on the front landing jacks. I use the Bal Chocks between the tires and a stab jack in front of the axles on both sides. With the combination of all of them, the bounce and shake is 99% gone. Took all of them off my 08 Flagstaff TT.
Old 04-06-2013, 09:48 PM   #7
Owner/Operator
RodeoGeorge's Avatar
I have a set of Eliminators headed this way, and for the life of me can't figure out why they state to position the rear arms the way they do. The stabilizers already provide more stability side to side, yet that's the way they state to install.
The way you have installed yours (front to back) makes a lot more sense, and that's the way I intend to install the rear set. Plus, they can be mounted to the frame itself for more rigidity.
RodeoGeorge
2013 Rockwood 8289WS
Mods: Central Vac, PI EMS-HW50C, 2025RV, (2) SCS225 Trojans, PD9260, Awning Remotes & LED Lights, Eliminators, External Water Filter,, Intellijacks
2008 RAM 3500 Cab&Chassis Hauler Bed, B&W Companion Hitch
All My Modifications are at this link:
https://www.forestriverforums.com/for...ons-36212.html
RodeoGeorge is offline   Reply With Quote
Old 04-06-2013, 10:21 PM   #8
elind's Avatar
Thanks, I guess I have my work cut out for myself. The Bal chocks are around $100 each for my TT. I'm going to create some out of 4x4's and threaded rods. The stabilizer bars might be the other project to do. It doesn't look to hard to make.
I think the third bar cross-way is needed because the power stabilizer center point is self adjusting to the terrain of the land. It could shift side to side. The third arm will make it solid.
2014 Wildcat 327ck
