Old 02-04-2015, 03:27 PM   #1
Can I bypass the WaterPur filter?
I have a Rockwood a frame camper, with water in a small sink, only. The case for the water filter has cracked and leaks badly. I don't need filtered water to wash my hands. I wondered if you know how to straight plumb the hose?
Paddle whisperer is offline   Reply With Quote
Old 02-04-2015, 03:46 PM   #2
Ford Idaho's Avatar
Unhook the water lines from each side of the filter head.
Pull easy like until you can hook the ends together with one of these.
Amazon.com : Orbit 1/2" Female Thread PVC Coupling for Sprinkler Pipe : Automatic Lawn Sprinkler Heads : Patio, Lawn & Garden
Lowes, Home depot or a local hardware store should have it.
If there is not enough slack buy two and a 3-4 inch threaded nipple hook it all together tight so it does not leak thread sealing tape will work.
https://www.google.com/search?q=1+2+...+nipple&imgdii=_
TT442 Teflon Pipe Tape 1/2" Wide x 520" Long
Old 02-04-2015, 04:34 PM   #3
Windywest's Avatar
X2 removed my filter housing last year, fittings cost me less than a dollar at Home Hardware. Removing the filter housing sure makes winterizing a lot easier, since the filter and housing are in the worst place to get at and replace.
Cheers from Alberta Canada
2011 Flagstaff 8526RLWS 5th Wheel
2011 Ford F250 4X4 Crewcab Superduty 6.7L Diesel
B&W 3300 Hitch for Ford 5th Wheel Prep package
Windywest is offline   Reply With Quote
Old 02-04-2015, 06:17 PM   #4
WrongWayRandall's Avatar
I've contemplated doing that to get more room down there. Are you planning on using (or do you already use) an in-line filter on your fresh water hose (outside), or do you just not care? I'm not sure that it really makes all the much difference (I lived in Florida for 17 years - nobody's water tastes bad after that) but I'd be interested in other opinions.
- R
1975 Westfalia (VW)
2014 Rockwood A122
WrongWayRandall is offline   Reply With Quote
Old 02-04-2015, 08:02 PM   #5
I'm very picky about the water that I drink... To the point that I bring all my water in steel water bottles. I only use the sink to wash my hands, etc. so I'm not too concerned about the campground water supply. Therefore, I just want to eliminate the filter.
I've had a number of campers, and this filter on the kitchen sink is new... So I think I'll be find without it...
Plus I get more cabinet space...
Old 02-04-2015, 08:36 PM   #6
Windywest's Avatar
We carry 5 gals of home tap water, and bottled water for drinking and coffee. I find campground water too chlorinated, ok for washing and showering, but not good for consumption.
Old 02-05-2015, 01:39 PM   #7
I removed the filter and use an in line from the hook up. Easy to use and I know have storage under the sink. Also no leaks
SFC USA RETIRED
2014 FJ Cruiser
2014 T12DDST
Its Cute but......
Total (2104-2017) 319 2018 (59)
dts3204 is offline   Reply With Quote
Old 02-05-2015, 01:41 PM   #8
Other A Frame questions May wish to join the A Frame Forum
SFC USA RETIRED
2014 FJ Cruiser
2014 T12DDST
Its Cute but......
Old 02-05-2015, 04:06 PM   #9
Windywest's Avatar
Old 02-05-2015, 04:11 PM   #10
Forest river has an A frame Forum located here A Frame Campers - Forest River Forums
SFC USA RETIRED
2014 FJ Cruiser
2014 T12DDST
Its Cute but......
bypass, water
