05-21-2020, 07:14 PM
Can't get bleach into FW tank to sanitize
2017 Cardinal 3250FL. My city water fill/inlet has a plunger inside the opening that won't allow me to pour bleach into the tank to sanitize my system, there is no gravity fill. I tried a section of hose with a funnel, that was a trip. All of my water functions are done from the main panel with various valve positioning.
Other than taking down a wall to access my pump, is there a way to gravity feed my FW tank?
Can I suction it like I do the pink stuff? Seems like that would take gallons of bleach to circulate the whole system and tank.
I searched the forum with every word and phrase I can come up with.
Thanks, Larry
05-21-2020, 07:18 PM
My unit doesn't allow for gravity feed either. I simply pour the necessary amount of bleach into my waterhose, connect it to my fresh water tank inlet and turn on the water. This pushes the bleach all through your line and down to your tank.
05-21-2020, 07:19 PM
You don't need much bleach 1/4 cup for each 15 gal capacity of your FW tank. That should be easy with an empty hose. Disconnect both ends of hose then drain it. Pour in bleach and holding both ends equal height connect one to water intake and other to hose. If connecting to hose bib on house kink hose to keep bleach in. Then run pump to fill water lines.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
05-21-2020, 08:03 PM
X2
And X2
2014 Prime Time Sanibel 3250
05-21-2020, 08:12 PM
Man, that was fast response, thank you all, great idea, why didn't I think of that... thanks!
05-21-2020, 08:15 PM
That's what makes this forum so helpful & informative.
05-22-2020, 11:50 AM
Yes, took me a season to figure out how to get bleach into my fw tank. A half to 2/3 cup easily fits into my 75' of hose.
Just remember to hold and keep the hose elevated so it doesn't come running back out.
Chris
2006 Sunseeker 2860DS Ford V10 5 speed with Tow/Haul
Winegard T4 In Motion Satellite Dish
Furion Rear Camera, RecPro 70" Recliners
Mohawk Luxury Vinyl Plank Flooring
2013 AWD Acadia Denali, Blue Ox Equipped
05-22-2020, 12:00 PM
I use the hose "trick" too. Just be sure both ends are elevated higher than what you'll connect too and that both ends aren't connected to anything so it is easy for the bleach to displace air out the other end. As a plus, this also means your hose gets a yearly cleaning =)
05-22-2020, 02:12 PM
We use an external water filter. We just take the filter out, pour the bleach into it, hook it to the spigot with a very short hose, hook up all 100 feet we carry and fill the tank.
05-22-2020, 02:14 PM
When did they remove the fresh water gravity fill ports on RV'S? Our 2004 Damon Challenger had one just aft of the fuel filler.
Kayo
2014 Primetime Sanibel 3051 pulled by a 2013 Chevy Silverado 3500HP dually diesel. Full timers wince 2003 with DW of 53 year. NPS Park Ranger
05-22-2020, 03:17 PM
One thing to be careful about these days is the different types of bleach available. Some, like the splashless bleach, are not appropriate for sanitation purposes. Only regular old-fashioned straight bleach works.
2019 Silverado LTZ 1500 6.2L 10 Speed 3.42 Max Trailering Package
2018 Freedom Express 192RBS
2022 Highland Ridge Open Air Lite Range 17BH
05-22-2020, 03:32 PM
I use liquid pool chlorine. I don't know if it's pure chlorine but it's 12% chlorine. If I can swim in it (at max 10 ppm, usually less) it must be okay. Though after running the diluted chlorine through the RV system, I do drain the FW tank and put in 5 gallons of fresh and run that through to get rid of most of the pool chlorine. I do this twice.
The biggest issue I have is the diluted chlorine that goes through the 6 gallon hot water heater. The taste of that can linger for days if I don't pull the anode rod out and drain the hot water tank. Typically that water only gets used for showers and dish washing so sometimes I don't bother to flush the hot water tank.
05-22-2020, 03:49 PM
i have a small pump that is run from the chuck of a drill. A little bit tricky but does work.
"Lurch" = Georgetown 2011 330TS
Toad = Jeep 2016 Cherokee
Pilot = Bob
First Mate = Xiangbing
Crew = Radar, NiuNiu & NaNa
05-22-2020, 04:20 PM
Fla5er
We also own a 2017 Cardinal 3250RL. All I do to add bleach (about 1/4 cup to 12 gals.) is use a small funnel and pour the bleach into a partially emptied hose, attach the hose to the fresh water fill and then begin the fill process. Easy to do.
05-22-2020, 05:38 PM
We prepare a diluted bleach mixture in a 1/2 gal pitcher and suck it in thru the antifreeze port with the pump then we use the external shower to fill the tank. That is also how we fill the tank from our 6 gal water jugs
Cathy & Jeff
Midland, Michigan
2020 Cedar Creek 34IK / 2019 Ram3500 CID
05-22-2020, 05:43 PM
No need to disconnect from water source. Just lift the hole and let it drain drain and there will be more than enough space to pour in a cup of bleach. Now it is important to keep the end up that you connect to the RV but that is pretty much automatic unless you water spigot is mounted 3-4 feet off the ground...
05-22-2020, 06:02 PM
Dahagen
What Qbud said.
05-23-2020, 08:53 AM
Ya know, we have a gravity fill on our camper. I used to struggle to get the bleach into the vertical opening and always spilled some.
When I read about this a few years ago it was an eye opening, "Why didn' I think of that?" moment.
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
05-24-2020, 07:37 AM
FR3 Grampy
I had the same problem but instead of using liquid bleach, I use bleach tablets. It'a way safer and I don't have to worry about any bleach splashing on anything. I break a couple of tablets into small pieces and place them inside my water hose. Then i connect my hose to the camper and turn on the water... No mess.
05-24-2020, 07:48 AM
Go buy a transmission fluid funnel, walk mart ,auto zone etc
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
