I had an idea, and since I'm usually "late to the party" many of you already know this, and my ideas are almost NEVER original, I decided to try spraying water on the roof of the TT during the hot part of the day to help the AC cool the TT. Well, the results are in but first a little more info on our science experiment.
We have a 33' TT with 1 15k AC unit, ducted through the ceiling. The outside temp at the time was about 102 with a relative humidity of about 10%. Inside temp was 84. There was no shade, full sun. I don't know what the temp of the water coming out of the hose was as I had no way to gauge it but I would call it "tepid". Ok, that's the setup.
I sprayed the roof with what I would call a good soaking until the drain spouts were pouring continuously. Then I went inside to record the results. I know, I'm a nerd.
The kids an I observed that the internal temp of the trailer as measured by a new digital thermometer dropped from 84 to 77! I was amazed! I didn't think it would be that effective. The resulting temp drop lasted for maybe 30 minutes is all, however. It would take multiple soakings to get through really hot afternoons but maybe enough to give your AC a rest.
We tried an hour later but the sun was going down and you could see that the droplets were not evaporating very quickly. No evaporation, no cooling and we saw the temp drop only 2 degrees.
Give it a try and see if it works for you! Cheers!
