Old 06-02-2024, 10:46 PM   #1
Everchill 12v fridge/freezer
If your having issues with freezer staying cold and fridge warming over time. Its your condenser coil behind your freezer draws. Condenser freezes and fan cant draw any air into the fridge. My trick was to put a battery op fan (small of course) in the freezer bottom drawer. Door seals are good. Sensor is good. Ohmed it out. Drain clear. The fan i added to the freezer seems to be doing the trick. It would normally freeze up with in a week or so. Set fridge on smart mode. 1degree c for freezer and 40f for fridge. Will be taking the front Cover of freezer to check the coils late this week. Back at ya then.
Vmurf2 is offline   Reply With Quote
12v, everchill, fridge
