Old 04-24-2020, 06:38 AM   #1
Gunslinger1's Avatar
Flushable Wipes
Cottenele Flushable wipes say they are safe in septic tank systems..I assume they'll be ok for the black tank. True or false?
1st time TT owner..
Gunslinger
Gunslinger1 is offline   Reply With Quote
Old 04-24-2020, 06:43 AM   #2
DONT do it! Unless you want to carry your Black Tank Contents around as long as your Wipes would be in your Septic Tank tooo Dissolve! Youroo!!
Old 04-24-2020, 06:49 AM   #3
I will have a permanent lot and will keep the TT there year round..
Old 04-24-2020, 06:53 AM   #4
lesptr's Avatar
Your TT has a holding tank, not a septic tank. Those wipes can get stuck on the valves and make it impossible to completely close the gate valve.
2017 Coachman Chaparral 336TSIK
2015 F350 6.7
lesptr is offline   Reply With Quote
Old 04-24-2020, 06:56 AM   #5
Prime Member
RV safe toilet paper, tank chemicals and whatever comes out of you are the only things that should ever go down an RV toilet.
2021 Transcend Xplor 247BH
Husky WDH with Sway Control
2013 Chevy Silverado 2500HD LTZ 6.6L V8 Duramax
Forever in my memory. Forever in my heart.
Laurie J. Wood 3/22/67 - 8/23/19
timfromma is offline   Reply With Quote
Old 04-24-2020, 07:05 AM   #6
Oaklevel's Avatar
Flushable wipes are NOT safe in a septic system (from experience) and NOT safe in an RV system... !!!!!!!!!!!!!!
Most regular toilet paper is fine though.
Do not leave your black tank valve open even on a permanent site, dump when full.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 04-24-2020, 07:06 AM   #7
KyDan's Avatar
Ask any metro sewer district- there is no such thing as flush-able wipes.
If it can hold together in the container and be wet and do it's job for you- it will hold together (not break down) in the black tank, dump valves and sewer system.
Peace!
Dan & Rita D
Blue Ox WD hitch
Camping days 2010-53, 2011-47, 2012-41, 2013-41, 2014-31, 2015-40, 2016-44, 2017-63, 2018-75, 2019-32, 2020-41
Old 04-24-2020, 07:11 AM   #8
Vermonter living in NC
They are only save if you are on a public sewer system. They are NOT safe for a septic system--therefore, not good for your black tank.
Same is true for all "bathroom" and baby wipes.
We had our sewer back up because the person we purchased our home from used these things all the time. The tank was full of them. Fortunately, there was a screen too our leach field and they didn't "flow" into that.
Papotvin is offline   Reply With Quote
Old 04-24-2020, 07:13 AM   #9
Prime Member
and if you must dump and your black tank isn't full, top it off with water first
Old 04-24-2020, 07:17 AM   #10
Flybob's Avatar
I would definitely not use them. If you want to see for yourself. Put one wipe in a container of water and some TP in another container of water. Wait a day and look at them. Wipe will get stuck on many things in the system and will cause issues before they disintegrate.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 04-24-2020, 07:22 AM   #11
do not use flushable wipes they really arent flusable. had a contractor that was staying in the camping portion of the resort i work for use them. besides complaints from the sewer district(the resort and only about 20 houses are on it) we had to unclog the sewer line for that sit 5 times and each time that was what was pulled out
2011 gray wolf 25rb
Jmkjr72 is offline   Reply With Quote
Old 04-24-2020, 07:51 AM   #12
Kanadian Kamper
kenandterry's Avatar
1st time TT owner..
Gunslinger
No, nope, nada, unh unh. You said you’re a 1st time TT owner.
There’s no negotiation here.
timfromma identified it all.
Ken and Terry
2018 Sunseeker 2430S with Trekker cap
and only rarely pushed by our 2017 GMC Terrain toad (4 wheels down)
Former Georgetown 330TS owner for 10 years with more mods than I can count.
kenandterry is offline   Reply With Quote
Old 04-24-2020, 08:33 AM   #13
Used Costco septic safe tp. Not a good plan! Took a lot of effort to get rid of it.
Went to Scott rv paper at Walmart! Seems better.
No way on wipes! Trash can only. Same with baby wipes.
It is a really bad feeling when you open the black drain valve and only get a trickle. I rinsed for hours. Then filled the tank and went for a 300 mile ride.
Cleared out. Ducked a bullet I think.
tomkatb is offline   Reply With Quote
Old 04-24-2020, 09:12 AM   #14
rbq
Local TV station has aired multiple stories of so called flushable wipes. They don't dissolve & just plug up pipes & sewer treatment facilities. Don't even think of flushing them, down the toilet or into your black tank or into a septic system.
2014 Chevy Silverado
2011 Rockwood Roo 233S
rbq is offline   Reply With Quote
Old 04-24-2020, 09:20 AM   #15
I am really surprised that you were Ever able to get rid of "Used Costco TP"! Youroo!!
Old 04-24-2020, 10:01 AM   #16
nomad297's Avatar
“Flushable” wipes put food on my table. Just about anything is flushable. I have several pictures of many of these things on my phone for sharing with my plumbing friends. I’m not sure if they would be suitable for posting here, though.
99% of the sewers I snake involve flushable wipes. They just don’t go away until I pull them out. Even the “Septic-Safe” wipes stay in one big piece. My most aggressive cutting heads don’t even chop them up — they just wrap around the blades and turn into a big ball of money for me.
Bruce
Old 04-24-2020, 10:06 AM   #17
Trailer Park Supervisor
NJKris's Avatar
I think everyone is unanimous here about flushing those things. And that's why I have a little trash can with a foot pedal for those very useful things that you don't want to mess up RV systems and septic systems, and municipal treatment plants with.
NJKris is offline   Reply With Quote
Old 04-24-2020, 10:07 AM   #18
NJKris's Avatar
Hahahahah!!!!!
Old 04-24-2020, 10:24 AM   #19
Mr. Dan's Avatar
Bruce
I’ve been waiting for your expert testimony since I’ve seen some of your posts warning about these things.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 = 108; booked = 0
Old 04-25-2020, 12:57 PM   #20
Go ahead, we service plumbers will happily take your money. As a camper / homeowner, don't do it, no such thing as a flushable wipe, makeup wipe, etc. Only TP and what comes out of your body should go down the drain.
Dale & Karen
2015 Lacrosse 311RLS
2006 F-250 The 06-6.0
Dwilcox is offline   Reply With Quote
flush
