10-03-2022, 09:55 AM
Homemade fire starters
Had some time this weekend to sit down and make these. I've had the material all summer long but just never got around to doing it.
Paper egg cartons, sawdust, wax.
Break them apart into 12 individual pieces, throw one in and light it.
*Not actually my picture but one I found from a google search.
My wife has a ton of those scented wax warmer things so I have a pretty good supply of wax and I have 2 grocery paper bags full of sawdust.
Made 2 and a half cartons of them over the weekend.
10-03-2022, 10:17 AM
nice tip
thanks
2014 Shamrock 183
10-03-2022, 10:36 AM
RV There Yet?
we use the wax melts and when they are done use them for fire starters. cotton balls soaked in wax will burn for about 10 minutes. i will have to start using my sawdust instead! its free after all!
2018 17RP
2009 Crew Cab King Ranch F150 "Goose"
10-03-2022, 11:18 AM
Dryer lint works too.
2015 Dynamax REV 24TB class C
10-03-2022, 11:59 AM
Canadian Member
We use those too but we buy them from a candle maker. They have a really nice scent that permeates the cupboard they’re stored in. If you’re using scented wax you’ll have the same benefit. They do work great although they can’t overcome when the Provincial Park’s wood is not dry!
10-03-2022, 12:53 PM
When we're allowed to have campfires, which hasn't been that often in the past 3 years, we use these:
https://www.walmart.com/ip/Zip-Fires...ntent=In-store
6 bucks for a 12 pack. No fuss, no muss!
If we have a torrential down pour, which happens every now and then, a road flare will get the wet wood going in a hurry!
2016 Salem 27RKSS
10-03-2022, 01:44 PM
A quick, easy fire starter can be made with a paper towel and some cooking oil.
Just pour about a tablespoon on the towel, making sure to keep at least one corner dry.
Light the dry part of the towel and it will wick oil from the rest to keep a good steady flame.
2020 Flagstaff Micro Lite 25BRDS SOLD!
2024 Brinkley Z3100
2021 Ford F-350 XLT 6.7L Power Stroke
10-03-2022, 01:46 PM
Nice job Iwritecode!
If you have the means then using the free stuff is a good way to go.
A friend of mine buys the $1.99 fire logs at Big Lots or Ollies and uses his band saw to cut them into about 1" thick discs. I think he told me he gets 10 from a log. He throws the discs into a plastic container with a lid. 1 disc works well to start a fire.
10-03-2022, 03:39 PM
We use a mix of dryer lint & sawdust together with the wax in an egg carton. Who would have thought dryer lint has a good use?
But we also stumbled on an easier (and more fun) fire starter. Wine corks soaked in a jar of rubbing alcohol. Works great - just avoid the 'plastic' corks used in some wine bottles now.
2022 Columbus 379MBC (Previous 2013 Rockwood Roo 23 IKSS)
2023 F-350 (Previous 2017 F250, 2005 F-150)
10-03-2022, 03:43 PM
Always Learning
I did dryer lint, cedar wood chips from a giant bag of pet bedding, and bought the cheapest candles I could find at yard sales and thrift shops.
I haven't thought about this article in ages!
https://learntorv.com/how-to-make-yo...fire-starters/
10-03-2022, 03:48 PM
Originally Posted by ependydad
All the above plus:
A cotton ball smeared with Vaseline.
I've also used BBQ lighter fluid just squirted into a small puddle at the bottom of the fire pit. The ashes it soaks int act as a wick.
10-03-2022, 05:26 PM
And while you're melting the wax, dip a few matches into the wax to make waterproof matches.
10-03-2022, 06:51 PM
This is my fire starter, works every time!
10-03-2022, 10:03 PM
There are some great ideas.
I use one of those fire starting logs. I just cut a small chunk and use my blow torch to start our campfires. I will use about two logs in a season of camping. Two to three small trips a month and if we throw in a big trip. Easy peasy and fires right up.
Past Tow vehicle but still own: 2017 Ford Expedition XLT EL factory tow package. Added towing mirrors, 10 ply tires on separate rims, sumo springs, larger rear sway bar.
Current tow vehicle: 2020 Ford F350 Lariat supercab
4x4. 7.3 gas. 4,400+lb payload capacity.
2021 Cherokee Greywolf 23MK
Equalizer 1,000lb WDH
10-04-2022, 06:37 AM
My wife would make these also and put six each in the goodie bags we would hand out at The Brass Ring Rally
2017 River Stone Legacy 38mb
2001 Kenworth T2000
2016 Smart for Two on deck
10-04-2022, 07:42 AM
I guess I am a gluten for punishment or a nostalgic purist. I still love the challenge of starting the fire like we did in boy scouts by simply preparing the kindling and seeing how few matches I can use.
22 Freedom Express 257BHS
19 F-150 3.5 Max-Tow
10-13-2022, 07:13 PM
I've used shredder paper also👍🏻
10-13-2022, 07:14 PM
OK, make it easy with stuff you have. Grab a handful of those grease covered potato chips.
10-13-2022, 07:40 PM
Those are all nice ideas above. They sound like a lot of work to me and I'm lazy and prefer to take the easy route.
I use a weed burner and a 20lb propane bottle. The propane bottle doubles as a back-up in case we run out of propane on the trailer. This actually saved a friend of mine on a cold trip in early spring. He arrived with 2 tanks but only had 1/2 a tank of usable propane and didn't realize it until night number 2. It was after hours when he ran out of propane and it was going to be near freezing that night. I gave him the weed burner bottle to get through the night until we could head to town and refill his tanks.
Image is for those that don't know what a weed burner is.
2016 F250 6.7L
2021 Grand Surveyor 272FLS
10-13-2022, 08:43 PM
I've used starters with various fillers in paraffin saturated egg cartons. I've used pine cones -- both saturated with wax and on their own. I've used Pringles potato chips, (which actually work very well, but don't burn for very long).
And yes, there are times when I revert to my old boy Scout days and use naturally available materials just for fun, and to show I still have the right stuff.
