Old 02-02-2011, 09:47 PM   #21
Oakman's Avatar
Hmmm, it seems as though herk7769 is Mr. Smarty Pants.
Yes, if my Honda has been sitting idle for a few weeks it will take about 10 pulls before it starts. However, if I run it once a week it will always start on the first or second pull.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 02-03-2011, 07:03 AM   #22
Herk7769's Avatar
Yes, it is a curse; no doubt...
HAM CALLSIGN - KC3FFW
Old 02-03-2011, 08:05 AM   #23
KyDan's Avatar
I can overlook Mr. Smarty pants as long as he's got
an extra cold one for me!
Old 02-03-2011, 08:11 PM   #24
Herk7769's Avatar
Always Lager and Guiness Draughts as cold as the fridge will go.
Old 02-03-2011, 08:18 PM   #25
itch'n to road trip
campnqueen's Avatar
Send a message via AIM to campnqueen Send a message via MSN to campnqueen Send a message via Yahoo to campnqueen
Hey Y'all...
first of.. our THREE Honda generators ALL start right up with one or two pulls... even our OLD Honda we have for our house...and the one for the house only gets run once in 6-8 months. So reliable!
Secondly...LOU! Dude...Guinness NEED NOT be that cold!!! It will kill the wonderful flavor of this nectar of the gods
2012 Ford F-250 King Ranch Super Crew Cab 4x4
2014 Work & Play 25ULA
Paula Drake, Ken Cooksey, Sunny Delight, Valor & Scarlet Begonia
Jasper Ga.
campnqueen is offline   Reply With Quote
Old 02-03-2011, 08:29 PM   #26
Herk7769's Avatar
The bottle and can draught are great. The bottles say serve as cold as possible. While pricey, they are every bit as good as from the tap.
This is not Stout; but the draught version. They are the ones with the compressed gas widget that "foams" the beer when you open it.
Old 02-03-2011, 09:40 PM   #27
MotocrossCamper's Avatar
I think a whole new thread got started here! How to get drunk while you winterize!
MotocrossCamper is offline   Reply With Quote
Old 02-04-2011, 06:55 AM   #28
KyDan's Avatar
I think I can modify Herk's plan to fit my needs.
Remove honda from truck.
remove beer from fridge.
Pull honda starter rope until arm gets tired.
drink beer
pull honda starter rope until arm gets tired.
drink beer
pull honda starter rope and honda finally starts!!
drink beer
plug charger into honda generator
drink beer
Happy Camping!
Peace!
Dan & Rita D
Camping days 2010-53, 2011-47, 2012-41, 2013-41, 2014-31, 2015-40, 2016-44, 2017-63, 2018-75, 2019-32, 2020-41, 2021-49, 2022-43
Old 05-22-2011, 07:08 PM   #29
First hand failure experience
After Hurricane Rita, and knowing we'd be buying a 5er, we bought a pair of eu2000's. Our dealer started it up and then asked how we wanted him to leave it - "dry" or "wet". I said 'wet' since I *planned* to periodically start it up. He said that was okay, as long as it was done every week or two.
Fast forward through the winter - okay, it's Houston, but it's still 'winter' - and there were a couple months without starting up the generator. In the spring, the generator was hard to start. Over the next few weeks, it got to the point that it would run for 1-2 seconds and then quit.
Taking it back to my dealer, he informed me that the carburetor jet had corroded nearly closed. An $80 repair later, it works great and has for the past couple years now that it gets started up every week or two.
The reason is ethanol and the carburetor fuel bowl. Ethanol in the fuel absorbs water which settles out in the bottom and causes corrosion. The jet through which the fuel flows is near/at this bowl, and it is so small that any corrosion will easily plug it closed.
Regardless of running the generator out of fuel, or using the pre-installed drain, there will still be a small amount of product left in this bowl. To truly get it "dry", open the drain while putting 1-2 psi of air in the gas tank. You will see a small amount of product spray through the drain, and then know that it is "dry".
When I asked my service guy about just using Stabil, he noted that it does NOT help with the ethanol water absorption issue. After reading the label, I found he was correct. However, I did find a marine grade version of Stabil (had to be ordered, it costs more and few stores stock it), but it did not actually state that it helps with the absorption issue.
As noted above, I keep my generators 'wet' but regularly start them up.
kablair is offline   Reply With Quote
Old 05-22-2011, 08:34 PM   #30
Bill_C's Avatar
On the bad side of keeping a carburator engine dry is the seals (gaskets) will dry out. Adding gas will expand them again but not necessarily in the right place or position. Add Stabil-izer.
DRINK COFFEE--do stupid things faster and with more energy ! Rockwood 5th wheel, Signature Untralite, 8244S
Tow Vehicle: Ram 3500 6.4 litre Hemi.
Bill_C is offline   Reply With Quote
Old 05-23-2011, 06:38 AM   #31
KyDan's Avatar
We actually had a recent discussion in another thread about
the water separation/ethanol issue.
My worry now is since my motorcycle is known to be
prone to gas tank rusting, I'll have to find some of that
marine sta-bil and hope for the best each winter.
It's ALWAYS something
Peace!
Dan & Rita D
Old 05-23-2011, 09:02 AM   #32
Wanna Be Camper
SaskCampers's Avatar
Seafoam is one of the most used by marine types. I stopped using Stabil altogether and only use seafoam now in my gas stuff and Texas Refinery DZLPEP Artic in my diesel.
John & Deb
2011 Flagstaff V-Lite 30WRLS
