I had a leak under my kitchen sink area that was very hard to figure out. I occasionally would get water on the floor but could not find where it was coming from. Checked drain pipes, checked fittings ( I thought) but could not pin it down. Then I was showing my brother and he saw a little water on the fitting that connects the sink facet to the pex suppy line. These are hand tighten fittings and I just missed it. After about a 1/2 turn on the fitting, it stopped it. I would check for tightness on all those fittings even if you don't obviously see water or feel it on the pipes. Don't get crazy with wrenches, just use your hand to see if all the fittings are at least hand tight. Good luch
Keith
Rockwood 2021 2104S MiniLite
2018 Toyota Tundra SR5
