Old 11-22-2020, 08:56 AM   #1
Chrisboy's Avatar
Mouse Free RV undercarriage spray
We had concerns about mice during storage and our dealer recommended this product when we were taking delivery of our new travel trailer. This is more of a prevention than a cure.
After some research I went the DIY route and bought a kit from their website which includes a spray gun. Easily halves the dealer cost and you get enough product to last at least a couple applications.
Here in Canada the product is rebranded as Store It Safe. It has the consistency of diluted petroleum jelly. No drip, no mess and non-toxic. Using an air compressor, you simply spray it on the entire undercarriage of your RV (frames, hoses, wires, wheel wells, jacks, axles, spray foam points, slide rails) The idea is that mice don't like this sticky stuff on their feet and they simply slide off or move along, given it has a peppermint scent as well.
The product wipes off easily with a towel if you needed to do maintenance work. I can see it doubling down as rustproofing and lubrication as well.
I have yet to see how it picks up road dirt when I take it out in spring, but I'd rather deal with that than mice.
Granted our trailer is brand new so I probably won't get mice yet anyway, I have more peace of mind knowing nothing is getting in as it sits in our backyard this winter.
ID:	243460   Click image for larger version
Chrisboy is offline   Reply With Quote
Old 12-01-2020, 03:20 PM   #2
SS Sixteen O four's Avatar
Rodents hate peppermint, peppermint extract duluted with water sprayed under a camper works also and has a pleasant odor and is pet safe. Bounce sheets on the inside of the camper and the truck when stored more than a month.
SS Sixteen O four is offline   Reply With Quote
Old 12-02-2020, 12:31 PM   #3
Retired Panpsychist
Theo's Avatar
Originally Posted by SS Sixteen O four View Post
{snip}...Bounce sheets on the inside of the camper and the truck when stored more than a month.
Dryer sheets (and other mouse repellent myths) are tested and debunked by Shawn Woods on his "Mousetrap Mondays" website and YouTube channel. Here is proof that the dryer sheet idea is a common myth:
https://youtu.be/sjZ2L26pJIU
Theo & Carol
2007 GoldenDoodle ("Cooper")
2020 Rockwood Roo 23IKSS
2015 F-150 4WD XLT SCab, 5.0L, 3.73, 36gal, HD Towing Pkg (53A), 1,980lb Payload
Theo is offline   Reply With Quote
Old 12-02-2020, 04:22 PM   #4
Just as confused as you
Scrapper's Avatar
It doesn't matter how new your rv is. We bought our 2014 TT new in August 2013, we closed it up for winter on October 15, 2013. I did all the recommended tricks such as Bounce dryer sheets on every square inch of floor, Fresh Cab pouches in every corner and cabinet, peppermint oil on cotton balls and when we opened it on April 14, 2014 for the spring we had mice.
As for peppermint, when I was in my 20's early 30's we grew peppermint and spearmint for the oil. We distilled it using steam and cold water in much the same way as moonshine. In those days we would get $5000 to $7000 for a 55 gallon drum. Peppermint oil is stronger than extract as it comes directly from the distiller.
Richard & Jill
Camping since 1989
I deserve hazard pay when camping with my relatives.
Old 12-02-2020, 04:28 PM   #5
Mothballs will deter mice and other rodents. I would not keep them inside the RV when you are using it, but during winterization they are fine.
Also make sure you have any holes sealed that mice might use to get into the trailer. They can get through REALLY small spaces, so seal well!
Rockwood Ultra Light 2304DS, towed by 2018 Ram Cummins Diesel 2500 4x4
RobbieH is offline   Reply With Quote
Old 12-02-2020, 04:54 PM   #6
Don't use Bounce, try Downy.
I've never even heard of the brand he used in that video. Downy sheets have worked for us for many years.
This past spring when we opened up for the season, the only places we found evidence of mice were the 2 places we didn't put the dryer sheets.
Iwritecode is offline   Reply With Quote
Old 12-02-2020, 06:02 PM   #7
Its likely the peppermint extract that did the job, however, the fabric softener sheets are staying because I don't want to mess with what works
Old 12-02-2020, 08:50 PM   #8
We have been using mothballs for years in our campers, from popup to hybrid to a couple travel trailers.
phipps33 is offline   Reply With Quote
Old 12-05-2020, 05:16 PM   #9
Mouse problems
Weve been using this for several years, smells good, no sign of mice. Scent Away RODENT RELELLENT
xomkid is offline   Reply With Quote
Old 12-05-2020, 05:54 PM   #10
Mr Towed's Avatar
you say it's re-branded as Store-it-safe in Canada... do you know what name they use in the US?
EDIT>>
I misunderstood that it's CALLED Mouse Free
https://mouse-free.com/
Travel Trailer: 2004 Flagstaff 25LB
New Tow Vehicle: 2017 F-150 3.5 Ecoboost, supercrew short bed FX4 Lariat
Old Tow Vehicle: 2009 Silverado 2500HD 4x4 Ext. Cab Short Bed
Travel Pooch:Sophie the Sato - Cats: Rhody and Hazy
2018:22nights / 2019:31Nights / 2020:18Nights
Mr Towed is offline   Reply With Quote
Old 12-05-2020, 06:41 PM   #11
moth balla
we put moth balls all over our Coleman tent trailer. Then distributed mouse poison, and left the rest of the box of poison on the floor.
When we opened the trailer 4 months later, the mice had neatly placed all the poison and moth balls back in the box and made nests out of the canvas and mattress.
Good luck with moth balls.
norml is offline   Reply With Quote
Old 12-06-2020, 12:07 PM   #12
Retired Panpsychist
Theo's Avatar
Moth Balls (and other mouse repellent myths) are tested and debunked by Shawn Woods on his "Mousetrap Mondays" website and YouTube channel. Here is proof that using moth balls is a common myth:
https://youtu.be/PCmAL3ErEMM
Theo & Carol
Old 12-06-2020, 12:17 PM   #13
glsimms's Avatar
Check out this humorous, yet informative video by Long Long Honeymoon. It dispels some of the myths about mouse proofing an RV.
Gerard
2017 Coachmen Apex 269RBKS with Summit Pkg.
2014 Ford Expedition with factory installed HD tow pkg.
Blue Ox SwayPro WDH
glsimms is online now   Reply With Quote
Old 12-06-2020, 12:44 PM   #14
B and B's Avatar
I did Store it Safe in Fall 2019. I have a 39 ft Fifth Wheel and hit every possible opening. First trailer ever No Mice! Same storage location as the Rockwood and Bighorn both had mice. The Landmark did not this past winter.
I reapplied to all areas I felt required it.
Big side benefit is this acts like undercoating and there is no rust on the frame or gas line where I sprayed. It does collect some road dirt but wipes off if needed. Non Toxic and no Brake Cleaner needed!!
Tried Irish Spring, bounce sheets, rolling peanut butter on pop can traps, mint extract nothing was fool proof.
I highly recommend this great Canadian Product!
Old 12-06-2020, 11:11 PM   #15
mothballs
I would rather have mice than smell moth balls
Old 12-11-2020, 05:07 PM   #16
Chrisboy's Avatar
So far, of the very few here that have actually used the Mouse Free product on their RV, Id say the success rate is 100%.
Curious if anyone experienced otherwise.
Old 01-11-2021, 01:23 PM   #17
mice
scent away rodent repellant . been using it five years and not seen one mouse dropping
Old 01-11-2021, 05:23 PM   #18
Scrapper's Avatar
Is it possible your mice are either house broken or in need of a dose of Ex-lax?
Richard & Jill
Camping since 1989
Old 01-11-2021, 06:15 PM   #19
I'm in Michigan & the mice are seriously looking for winter shelter......peppermint/oil & the inside radio on a "Talk" station 24/7......works for me.....not a trace of the little buggers! .....
Unencumbered By The Thought Process
tande is online now   Reply With Quote
Old Yesterday, 10:52 PM   #20
Back in March I had to leave Arizona in a real hurry in order to get back home before the Canadian border was closed. Consequently, I had no time to do anything with my KZ as far as rodent proofing. I finally made it back to AZ after 10 months and was pleasantly surprised to see absolutely no evidence of any rodent or insect intrusion. I'll be doing a more thorough inspection in the near future, but so far it's looking good. In the future I'll do some sort of peppermint oil application in the storage areas.
2019 Silverado LTZ 1500 6.2L 3.42 Max Trailering Package
2018 Freedom Express 192RBS
2016 Silverado LTZ 1500 5.3L 3.42
2015 Jeep Wrangler Rubicon 3.6L 4.10
2020 KZ 130RBSE
AlaskaErik is offline   Reply With Quote
mouse free rv spray
