Old 02-29-2020, 06:58 PM   #1
DavidJ's Avatar
Murphy bed problems part I
If you like to sit in bed, with your back propped up with pillows against the camper wall, beware!
The weak bed frame will not hold your weight and it will bend.
An indicator of this is it gets harder to clip the bolts that hold the bed in place when not in use. My Murphy Bed Part I covers the Piano Hinge problem.
I discovered this new problem by looking through the access compartment I created fixing the Piano Hinge problem. With the bed in the down position, one side of the bed frame hung down farther than the other. See pic. This view showed me a bent bed frame!
I also laid a straight board on the bed to measure the bend. See pic.
So to fix this issue, I screwed down 2 - 2x3s to the length of the bed to strengthen the bed frame. See pics.
The 2x3s now do not allow enough room to hold the mattress when put away, so we fixed that problem. We screwed down a 1x5 at the bottom running the width, to better hold the mattress onto the frame when putting the bed away. See before and after pics.
Even though this greatly strengthened the bed, we probably will not put all of our weight at the head of the bed anymore. 😕
Sorry about the pic orientations. It was straight when I uploaded them.
ID:	224189   Click image for larger version
ID:	224190   Click image for larger version
ID:	224191   Click image for larger version
ID:	224192   Click image for larger version
ID:	224194   Click image for larger version
DavidJ is offline   Reply With Quote
Old 03-01-2020, 09:29 AM   #2
DavidJ's Avatar
The title of this should read “Murphy bed problems part II”
David & Cindy in Iowa
2017 RockWood 2504S travel trailer
2015 Chevy Silverado 1500 LTZ
Old 03-03-2020, 10:31 PM   #3
Made up a fix as I went along
We had the same problem of the Murphy bed with a bending and cracked frame. I took the platform off the piano hinge, removed the bottom paneling (room wall paneling), straightened the frame using clamps and blocks, then sandwiched the aluminum frame with 2 pieces of angle aluminum and used hose clamps to snug it all together. I only had to do it on one side but this could be applied to all four sides. I glued the paneling back on and replaced the trim.
It wasn't an easy job but it is still holding after 3 more seasons of travel.
ID:	224423   Click image for larger version
CastletonRVers is offline   Reply With Quote
Old 03-04-2020, 09:47 AM   #4
DavidJ's Avatar
Yeah you did it right. Mine was more of a patch fix but I believe it is fine. We are currently traveling for 3 months. Once we get home late March, Iíll check it again and see if my fix held.
Thanks for your pics.
bed
