Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 05-10-2014, 06:08 PM   #21
My fridge is located in a slide. Would you check level with slide in or slide out?
thecigarmann is offline   Reply With Quote
Old 05-10-2014, 07:29 PM   #22
BamaBob's Avatar
So is Ours.
If the Rig is level with the slide in, it will be level with the slide out.
If you have any other questions, don't hesitate to ask TheCigarMan (BTW what rig do you have? Most of us put that info in our Signatures)
Nights Camped: 2013 - 24 • 2014 - 42 • 2015 - 56 • Jul 2016 - Fulltime •
BamaBob is offline   Reply With Quote
Old 05-10-2014, 09:29 PM   #23
Originally Posted by HSVBamaBob View Post
So is Ours.
Sorry about that. I haven't taken the time to set up my signature.
I own a 2014 Rockwood 2703WS.
Old 05-11-2014, 02:42 PM   #24
Always Learning
So is Ours.
Ours changes slightly side to side, but it's not nearly enough to stress about. After a few setups, we learned to account for it. (Wife and I are spastic about being perfectly level- our doors swing closed if we aren't as I can just naturally feel it).
Checkout my site for RVing tips, tricks, and info | Was a Fulltime Family for 5 years, now we're settlin' down for a spell
Old 05-11-2014, 05:53 PM   #25
Timex's Avatar
I might want to jump in and say, when pulling up on blocks, boards, sticks (whatever), make sure your tire is completely on, not hanging over the side. It keeps stress off the tire when setting flat on the object your are parked on.
Timex is offline   Reply With Quote
Old 05-11-2014, 08:50 PM   #26
Another question. If I check for level inside the fridge it should not matter whether the slide is in or out. Right? Now does this mean that when my fridge is level then the fixed floor of my trailer should be level as well? How level is everything inside a trailer?
2016 Ram 2500HD 6.4L Crew Cab 4X4
2022 Rockwood Signature Ultra Lite 8324SB
Old 05-11-2014, 09:11 PM   #27
Timex's Avatar
Be sure to put a thermometer in the fridge as well. When the trailer gets level, the fridge will be able to get it's coldest.
Old 05-12-2014, 04:05 PM   #28
BamaBob's Avatar
Spot on! When we level, we usually will open the door and secure it open, lay our level on the floor and 6 Actual (DW) will eyeball it and put out the legos while I do the backing.
Old 06-21-2014, 05:16 PM   #29
I know this is an older post, but this is a vote for the BAL leveler. We picked a new one up off Craigslist cheap for our single axle trailer and it is quick and easy. It wasn't even as heavy as I thought it might be and it stores flat.
cowbelle is offline   Reply With Quote
Old 06-25-2014, 09:43 AM   #30
Scubaboy323's Avatar
Does anyone have any experience with an Anderson Camper Leveller, posted earlier by BamaBob? Looks slick, though pricey, just wondering how good they are.
Cheers,
2014 Rockwood 8282WS
2012 SCREW F150 5.5box
3.5L EcoBoost, 3.73 Axle, HD/Max Tow Package
Reese Revolution 16k pro
8 night camping 2014
Scubaboy323 is offline   Reply With Quote
Old 06-25-2014, 10:09 AM   #31
Always Learning
There's a long running thread on them here:
http://www.forestriverforums.com/for...ers-43295.html
Long and short of it, other than needing to trim them up a bit for axles/wheels that are close- I don't think I've heard any complaints about them. (Though, I haven't read every post in that thread and have never used them myself.)
Old 06-27-2014, 09:15 PM   #32
zapme01's Avatar
I have also purchased this Andersen leveling wedge. Looks so easy in the video. I am very eager to try this.
zapme01 is offline   Reply With Quote
Old 06-27-2014, 09:21 PM   #33
DW's 401(k) Plan
DaGrinch's Avatar
Love my Andersen Levelers. Best thing I've bought for my camping pleasure.
"Sunny" the 2017 Sunseeker 3010DS
2006 Jeep Liberty Toad
.... and lovin' life........MOST of the time.
DaGrinch is offline   Reply With Quote
Old 06-27-2014, 10:24 PM   #34
Capt. Mike's Avatar
[QUOTE=ependydad;608755]Ours changes slightly side to side, but it's not nearly enough to stress about. After a few setups, we learned to account for it. (Wife and I are spastic about being perfectly level- our doors swing closed if we aren't as I can just naturally feel it).[/QUOTE]
On ours, we need to have the driver's side about 1 inch higher than the other side before we put the slides out. Two slides on the same side, extended, hangs a lot of weight out that side, and drops the left side of the trailer to just about perfectly level.
Mike and Yvonne
and Sophie, the little white dog
2017 Columbus 320RSC
2021 Chevy Silverado 3500HD DRW 4X4 Duramax
“It's not how old you are, it's how you are old.”Jules Renard
"It's not the years...it's the mileage." - Indiana Jones
Capt. Mike is offline   Reply With Quote
Old 06-29-2014, 07:05 AM   #35
GC
So when you level side to side, must you put boards under both of the low side tires or just one of the tires? I've always done both, but see some who only do one tire.
GC
garycarson is offline   Reply With Quote
Old 06-29-2014, 07:18 AM   #36
I raise Both! Youroo!! On (1) side!
Old 06-29-2014, 09:26 AM   #37
Always Learning
I raise both but I've heard if you only raise one, you get 1/2 the leveling amount. We try to "dial in" our leveling by raising just one tire when we get it close. Don't know if it really works or if it just let's us feel better.
Old 06-29-2014, 09:45 AM   #38
Raise both on the same side the same amount, otherwise, you're overloading a tire. Overloading a tire momentarily is ok while traveling, but not for an extended period of time parked.
Old 06-29-2014, 09:58 AM   #39
AquaMan's Avatar
You think that applies with the Equaflex system also? I can see where it would apply to a torsion axle system, but the idea of the Equaflex is to spread the weight evenly across both axles, thus both tires. Haven't studied it thoroughly, though. Just a thought.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
Old 06-29-2014, 10:18 AM   #40
Originally Posted by AquaMan View Post
You think that applies with the Equaflex system also?...
Yes!
leveling
