There is a plastic roller held with a wire loop that has a little bent metal hook. The curtain hangs from those weak hooks.
After you replace the shower head with an Oxygenics (fast cure for a weak flow), replace the shower curtain rod with an ExtendAShower and use normal curtain loops. Amazon sells some loops with roller balls on them.
2019 Cherokee Wolf Pup 16BHS flipped axle, 5K springs, 400AH LiFePO4, 3K inverter, 400 watts CIGS solar
2019 Ford F-150 S-Crew 5.5 bed V8 w/tow package, ITBC, Tow Mirrors, 3.55, SumoSprings, 7000# GVWR, 1990#CC
Husky Centerline TS WDH 400-600# spring bars
