Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 06-16-2010, 02:16 PM   #21
powerboatr's Avatar
this sure makes the task of turning it and watching the picture go good to bad
in all my years i never thought any different until now
Living in the Piney Woods of Texas.
powerboatr is offline   Reply With Quote
Old 06-16-2010, 05:31 PM   #22
Grape Escape
And how does one know where the broadcast antennas are? This whole topic seems to be a waste of space. I have yet to see towers in any city. They are usually located outside in rural areas where land is cheaper. As far as I am concerned sometimes you get lucky and find good reception and many times not. Rotating via 360 marks on a protractor??
Nothing scientific about it. Raise the antenna up and point in some direction and when you get alot of stations fine tune it in which ever direction they come in.
2008 Cardinal 30RKLE 5th wheel sold
2006 Rockwood 2607, 2001 Traillite
55 nights 2009, 53 for 2010
44 for 2011, 38 for 2012, 35 for 2013, 51 for 2014
dezolen is offline   Reply With Quote
Old 06-16-2010, 05:45 PM   #23
MtnGuy's Avatar
I think the idea of this thread is to get the antennae aimed close to known towns and cities, do a scan, and then after getting the channel you can fine tune the antennae to get the best picture.
Old 06-16-2010, 05:56 PM   #24
Herk7769's Avatar
Smile That part is easy!
Just visit:
Address
Input your zip code (or address) and search!
A list of stations, compass heading and distance to broadcast tower as well as its most likely signal strength and channel.
The stations are ranked by ease of reception.
Easiest on the top; hardest on the bottom.
A map and a compass will get you the best reception possible in your area.
HAM CALLSIGN - KC3FFW
Old 06-22-2010, 01:16 PM   #25
skeeterbait8's Avatar
THANKS LOU!!!! Most times where I'm at I already have a good idea of which direction what major towns are. That I'm good at. It was finding out what part to point is what was getting me.
Official member of the "Roo Kroo"!
2009 - 4, 2010 - 135
2011 - 95 and counting
skeeterbait8 is offline   Reply With Quote
Old 06-22-2010, 01:32 PM   #26
MtnGuy's Avatar
On a related note, I camped at Loft Mtn. on the Skyline Drive over the weekend, and got 73 channels !!! Geez, that is more than I get on cable at home.
I do 3 channel searches with the antennae pointed approximately every 120 degrees.......seems to work well.
Old 06-22-2010, 02:00 PM   #27
At Cumberland Gap NHP I get two. 10.1(NBC) & 10.2(Knoxville weather).
Old 06-22-2010, 02:11 PM   #28
Herk7769's Avatar
The Internet widget
Works great. Still shopping for a circular protractor.
That mod is awesome.
Old 08-31-2010, 12:35 AM   #29
I'm considering adding the Wingman to the antenna on our Lexington, but if I do, it looks like the new extension will protrude over the edge of the roof by a good many inches when the antenna is down. To fix this, can the antenna be switched the opposite side of the mount so that the Wingman would then sit completely on the roof when lowered?
Cyberstork is offline   Reply With Quote
Old 08-31-2010, 06:03 AM   #30
jaxfl's Avatar
I have the Wingman extension and still if you are more than 50 miles from a tower, forget the TV and load the DVD. I just spent the weekend at Gamble Roger that is 30 miles from Daytona Beach and because it is a low area you get NO TV. Last month I was outside St Augustin Fl and because of heavy trees got no tv. Makes me made because at home I get more that 40 channels setting in the drive way.
jaxfl is offline   Reply With Quote
Old 08-31-2010, 06:43 AM   #31
Herk7769's Avatar
No. There is no way to mount the Wingman "Backwards" on the amplifier body. I am not sure if it is possible to mount the existing Winegard antenna on the other side of the mast. The Wingman will only mount as shown on the control amplifier.
Replacing the Antenna head you have with one of the newer ones from King Controls might be your only option.
King Controls Jack TV For Free OA8000 VHF UHF Amplified TV RV Antenna (OA-8000) - King Controls - OA-8000 - Antennas for RVs&sku=
Old 08-31-2010, 08:36 AM   #32
MtnGuy's Avatar
You cannot mount the Wingman on the mast side of the antennae. But I read somewhere that you can cut the Wingman to make it shorter......there are no wires in there. The shorter Wingman probably won't work as well cut down, but should still improve the reception some.
Old 08-31-2010, 08:45 AM   #33
Herk7769's Avatar
While it might work (I doubt it though as the elements are tuned) for 20 bucks more you can replace the whole shooting match with an amplified antenna head direct replacement that works as well as the augmented basic winegard/Wingman combination.
Old 04-16-2012, 07:04 PM   #34
For the rest of us who cant afford a satellite antennae or service contract there are ways to do this if you are not smart like me. I graduated 8th grade after all! I bought a TV for $300 that had a signal meter if you can figure out how to get to it. My husband-in-law graduated 6th grade and he couldn't do it...
Once you get someone to turn on the signal meter for you just start crankin' that thing around SLOWLY until you peak the meter.
Dang, wonder where I could have gone if I went to high school!!!
41railbuggy is offline   Reply With Quote
Old 04-16-2012, 07:34 PM   #35
Herk7769's Avatar
That would be a handy feature on any "over the air" television broadcast.
Since the new broadcasts are all digital and directional, these signal meters should become more common and are certainly helpful.
FYI, digital and high definition TV has not one thing to do with satellites or subscriptions. It is like "old" TV; just better.
Old 04-16-2012, 10:44 PM   #36
Thumbs up
Yep, I'm old enough that I cut my teeth on B&W TV LOL!
I have not paid for cable or satellite in quite a while. Get about 25-30 channels around Tampa Bay area and the quality is as good or better than cable HD plus you get all the channel info etc. now since it went digital. Who says things never get better
Old 04-16-2012, 10:57 PM   #37
Herk7769's Avatar
You are very lucky to be in a high density broadcast area.
Others are not so lucky.
Old 04-16-2012, 11:03 PM   #38
Yes I know. I grew up with 2 channels of B&W in mountains of NE GA...high tech though. We had a rotor to turn the antennae automatically between the two stations!
Old 04-17-2012, 07:27 AM   #39
MtnGuy's Avatar
Oh yeah. I remember traveling to a cousins house in 1969 to watch the moon landing in color......come to find out, the moon walk was in black and white.
We disconnected from cable after 1 too many bill increases. I have a $100 antennae on a 12' pole beside my house, and get about 20 channels, including some from about 80 miles away with a small mountain in between.....don't know how that is happening, but I ain't complaining. The over air picture is much better than the cable picture.
I looked into switching to an antennae after realizing I could get 23 channels in my RV sitting by the house......of course that antennae is rotational, so I could get more channels with that.
Old 04-17-2012, 07:49 AM   #40
Herk7769's Avatar
This is because over the air broadcasting is digital AND High Definition. If your TV is High Def; you will get a high def image.
Without a cable box (rental) AND the "High Def Package" (extra money) option, you are getting a down sampled low (standard) def analog picture that is stretched out to fit your screen.
winegard
