First of all, CONGRATULATIONS to your daughters! I'm sure they'll represent our state well!
I'm not sure how much weight the shower enclosure will support on your rig, but with all all the jostling, you might want to consider using Command Jumbo 7.5-lb Utility Hooks. Just make sure what hangs on each of them is <7.5-lbs (with hangars). You can temporarily affix a number of them up high on the appropriate surfaces so the outfits don't touch the ground. Of course, you can remove them when you return home after the event.
HTH!
Theo & Carol
2007 GoldenDoodle ("Cooper") R.I.P.
2020 Rockwood Roo 23IKSS
2015 F-150 4WD XLT SCab, 5.0L, 3.73, 36gal, HD Towing Pkg (53A), 1,980lb Payload
