Old 02-25-2018, 04:10 PM   #21
Tigger1's Avatar
Originally Posted by sasch View Post
I was able to find a matching woodgrain molding (1/4x3/4) at a local Flagstaff dealer that I needed for a vertical trim and that may cover your caulking spot if that is what you're looking for - sure a Rockwood dealer would have thew same thing.
Thanks, yes Iím looking for something to cover the horizontal caulk line.
2010 Toyota Tundra DC SR5 5.7l 4x4
2020 Grand Design Imagine XLS 22MLE
Andersen WDH
2018 Rockwood Mini Lite 2104s
2014 Jayco x17z Hybrid
Tigger1 is offline   Reply With Quote
Old 02-26-2018, 09:42 AM   #22
Wolverine 1945's Avatar
Very nice Job !!! Maybe Chair Rail would work as trim ???
We will buy another RV without some sort of seating other than the Damm dinette set !!!
Wolverine 1945 is offline   Reply With Quote
Old 02-26-2018, 10:04 AM   #23
Tigger1's Avatar
Thanks Wolverine!
A chair rail is an option. Still thinking it over.
We have another decision now. Someone wants to buy the dinette. First I have no idea what to charge, second what happens when we eventually sell the trailer and the buyers want the dinette? Need to think this over.
Andersen WDH
Old 02-26-2018, 10:40 AM   #24
Originally Posted by Tigger1 View Post
Thanks Wolverine!
Are you able to recline on your Love Seat ???
Old 02-26-2018, 11:15 AM   #25
DouglasReid's Avatar
Originally Posted by kenandterry View Post
Tigger1....
Did you try Goo Gone for removing the caulking line?
It works really well on removing sticky stuff in all kinds of situations.
https://www.walmart.com/ip/Goo-Gone-...ttle/666785817
VERY elegant solution. There is a nice space on the side or behind even to store a couple of TV trays to eat on, as someone else suggested.
If Goo Gone, which is an orange oil based product, does not remove the caulk line you can try Goof Off. Be careful and test it in an inconspicuous area first though because it is petroleum based and could possibly damage the substrate. I think the paneling is covered with vinyl wallpaper so I would think it would be OK, but Id test it first some place hidden to be sure.
2008 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline   Reply With Quote
Old 02-26-2018, 11:53 AM   #26
Tigger1's Avatar
Yes, even though these recliners are not wall-huggers it is easy to slide the loveseat forward to the edge of the dinette carpet, the top layer which moves with the slide. From that point fully reclined in an almost flat position is approximately 6 ft. top of recliner to bottom of my feet. This leaves us a little under 3 ft. for someone to go around and access fridge, bathroom or pantry. These recliners, and perhaps other lazy boy recliners, are two functions, i.e. the seat and back move separately from the foot rest. Iím sounding like a lazy boy salesperson now Full disclosure, Iím not.
We will push the unit back and strap it with a web-strap when traveling. I think they could act as sleepers if one chooses therefore not losing the dinette sleeping functionality.
Andersen WDH
Old 02-26-2018, 11:56 AM   #27
Tigger1's Avatar
Thanks!
I tried Goof Off and it removed the finish and left a white spot. I only did a small place. When I get to the store Iím going to pick up some Goo Gone and give it a try.
Andersen WDH
Old 02-26-2018, 12:11 PM   #28
Thanks!
It will do the same as Goof Off !!!
Old 02-26-2018, 12:14 PM   #29
I'd love to do this, but I really don't want to lose all that storage.
2017 Rockwood MiniLite 2506S
2019 GMC Sierra 6.2L
2017 Colorado D-Max pulling 2017 Tracker 175TXW
Days Camped in 2020: 27
bshort is offline   Reply With Quote
Old 02-26-2018, 12:18 PM   #30
If you do not want to use Chair Rail,,, maybe you could go to a dealer and find some battens that match your wallboard ???
Old 02-26-2018, 05:36 PM   #31
Lakesdr's Avatar
21 FBRS
I love what youíve done, in the micro lite (21fbrs) we have this nasty jackknife, it was made only to be replaced. My question is whatís under the middle? On the floor of ours is the slide motor, dead center. If that is air space it will work. Hope to get into it this spring and get something we can live with. Anyone done this to a micro?
Steve & Terri
Lakesdr is offline   Reply With Quote
Old 02-26-2018, 06:15 PM   #32
Tigger1's Avatar
Originally Posted by Lakesdr View Post
I love what you’ve done, in the micro lite (21fbrs) we have this nasty jackknife, it was made only to be replaced. My question is what’s under the middle? On the floor of ours is the slide motor, dead center. If that is air space it will work. Hope to get into it this spring and get something we can live with. Anyone done this to a micro?
The console has a solid back and lower drawer. When I removed the drawer this is what the inside looks like. The open space in the center showing the carpeted floor is 13” w x 10” d. They do sell the pinnacle recliners separtely.
Andersen WDH
Old 02-26-2018, 06:47 PM   #33
Lakesdr's Avatar
21fbrs
Thanks Tigg, looks like it might work, the two bottom plys, the front would work over the motor, the back will have to go, for the drive gear is there. Again thanks, we need to resolve this in the spring, what we have now is not tolerable
Steve & Terri
Old 03-15-2018, 01:19 PM   #34
Wow...wow...WOW!
That is NICE!
RSW3 is offline   Reply With Quote
Old 03-16-2018, 07:41 AM   #35
rp53's Avatar
can't be done, the slide motor is under the Jackknife sofa, i have looked at several options and have yet to find one that will work, let me know if you find anything that will work
2017 Micro Lite 21FBRS (sold)
2019 GMC Sierra 2500 HD extra cab Z71
looking for the perfect 5er over the winter
rp53 is offline   Reply With Quote
Old 03-16-2018, 09:32 AM   #36
I also looked @ our Sunseeker 2500TS a year or so ago,,, wanted to chance to a sofa bed Our slid out is raised,,, decided there was no way to change it !!!
Live & Learn !!!
Old 03-16-2018, 04:59 PM   #37
I purchased a couple of floor chairs when we had a trailer with the slide motor under the jacknife. Better than the jacknife but not great.
Rockwood 2604WS
Ford F250 Diesel
Blue Ox Sway Pro
allenb12 is offline   Reply With Quote
Old 03-17-2018, 08:07 AM   #38
Our old Flagstaff TT had a pretty comfortable Sofa bed,,,
As long as we had a small coffee table to our feet up on !!!
For us that is a must !!!
Old 03-19-2018, 12:26 PM   #39
Tigger1's Avatar
Added a wall-paper border today with some rust, brown and greens to match loveseat and curtains to hide caulk line. Second photo shows recliner fully reclined which gives us about 30Ē to go around to access fridge etc.
Andersen WDH
Old 03-19-2018, 04:03 PM   #40
Lakesdr's Avatar
Swapped out
Very Very nice. Now why cant FR think along these lines rather than that nasty little jack knife. Jussayin 🤔
Steve & Terri
