Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 03-12-2014, 02:54 PM   #41
Scootdawg's Avatar
Its great catching up on the forums, this will be my first de-winterization (if this blizzard ever quits). I was looking on line and after I flush out the RV-Winterization fluid, I seen this sanitizing solution that you flush into your FW tank and lines, then drain out. Is it a waste of money where as bleach can do the same thing. Or should I purchase the tank sanitizer and just keep flushing my lines afterwards? I am a noob at this. My first RV (Sunseeker 2900) and I don't want to ruin it. Thank you all!
Scootdawg is offline   Reply With Quote
Old 03-12-2014, 03:01 PM   #42
TURBS's Avatar
Use bleach.
1 cup per 30 gallons.
TURBS
Sabre owners united!
Old 03-12-2014, 03:21 PM   #43
SKnight's Avatar
Originally Posted by f1100turbo View Post
By the way google " bleach over dilution" if you think I'm blowing smoke.
Have a great day.
TURBS
I did. Heres the very first hit.
Originally Posted by Link below
  1. Bleach containing 5.25% sodium hypochlorite should be diluted as follows (demonstration short):
  2. 1:99 diluted household bleach (mixing 10ml of bleach with 1litre of water) can be used for general household cleaning.
  • 1:49 diluted household bleach (mixing 10ml of bleach with 0.5litre of water) is used to disinfect surfaces or articles contaminated with vomitus, excreta, secretions or blood.
Department of Health - The Use of Bleach
So I'm going a bit stronger than they say here, like I said, I tend to use half a gallon per 20ish gallons of water, so I'm at about a 1:40 ratio. Do I want to disinfect the system? Yep, only reason to do it, correct?
Old 03-12-2014, 05:39 PM   #44
Canadian Member
My local Health Department says to use 2 oz. of bleach for every gallon of water to make a "sanitizing solution" for a spray bottle.
http://www.durham.ca/departments/hea...y/duhev260.pdf
The recommended 1 cup (8 oz.) for 30 gallons is no where near that strength but I realize I'm not trying to mix a spray on sanitizing solution. I'm probably using something like 1.5 to 2 cups of bleach for my 30 gallon tank - just enough that I can smell it coming out of the taps.
All that being said, I think I'll check with our IPEX rep to see if my stronger solution would damage the plastic water pipes in an RV.
2019 Rockwood Signature 8290BS, Reese Revolution pinbox and B&W Patriot 18K hitch
antifreeze, fresh water, tank, water, water tank
